overcharged AC - Ford Truck Enthusiasts Forums
overcharged AC
Old 07-17-2006, 07:43 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
overcharged AC
What are the symptoms of an overcharged AC system?
I converted my 92 explorer to R134a and I believe that I might have overfilled it. The gauge set is showing just under 100psi with the engine off, but the compressor is cycling on and the air blows at about 70-80 degrees. This would tell me its low, however I have put in 3 cans which is supposed to be over full. I am confused, help!
Old 07-17-2006, 08:06 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
What are your high and low side readings while the compressor is running?
If they are equal, the compressor isn't compressing.
Steve
Old 07-18-2006, 10:04 AM
fefarms fefarms is offline
fefarms is gaining momentum as a positive member of FTE.fefarms is gaining momentum as a positive member of FTE.
If you have too much refrigerant, duct temps will be too warm, not too cold.
The refrigerant has to be able to expand fully from a liquid to a gas in order to extract the most heat. An overcharged system leaves too much of the refrigerant as a liquid and you don't get much cooling.
100 PSI engine off sounds too high. A correctly charged R134a system runs about 70 PSI engine off as I remember it, but this is a bad way to estimate charge.
The real test is with the compressor cycling. The low side should cycle between 25 and about 45 PSI. The high side should reach a max of about 2.5 times the ambient temp. The compressor cycle should be about 7 seconds on, 10 seconds off at "reasonable" ambients (say below 85 degrees). If the cycles are longer than that, the system is overcharged. If the cycles are shorter than that, the system is undercharged.
Old 07-18-2006, 05:33 PM
MisterCMK's Avatar
Avid Winter Hater
Excellent info guys. I have to exchange my gauge set as the high side hose literally blew up, but I will be doing that tomorrow or Thursday. I suppose the next step is to completely evac the system and put a vacuum on it and start from scratch.
Old 07-19-2006, 05:50 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to all
The next step is to hook up your gauges and with the A/C on and engine running at about 1,200 rpm, bleed off a few ounces of refrigerant at a time until the low side pressure is back in the correct operating range. This assumes that the system was properly evacuated before the current charge was inserted. BTW, the pressure with the engine off is basically irrelevant to correcting this problem. All it shows is that there is *something* in there, but it doesn't indicate correct/incorrect charge.
Old 07-21-2006, 05:05 PM
MisterCMK's Avatar
Avid Winter Hater
Well, I've got the vacuum pump on the system right now. We'll see if evacuating all the freon and recharging it will fix the problem.
Old 07-24-2006, 10:41 PM
MisterCMK's Avatar
Avid Winter Hater
Well, I recharged the system and its still not cooling right and the compressor is still cycling too often. I went over the factory service manual and it looks like the evaporator or orifice tube is plugged. I just don't want to sped the money for a new evaporator and another $20+ on refrigerant.
Old 07-25-2006, 08:35 AM
Quote:
Asking again. What are your readings? Whata re the ambient test conditions? Did you follow correct preparation procedures for testing?
If you want assistance, you have to answer questions that request relevent information. None of your information has been useful in understanding what is wrong.
If you just want to document whatever you're doing stumbling around, start a diary.
Steve
Old 07-28-2006, 08:35 PM
Holmesuser01 Holmesuser01 is offline
Holmesuser01 is starting off with a positive reputation.
Have you checked to see if the evaporator is plugged with leaves and crud?
Pull the blower fan and feel around inside there. Get all the dirt and leaves that you can, then using a crevice tool on a vacuum cleaner, clean out the rest of the crud. It will often make a big difference.
My '83 was loaded with leaves.
Old 07-29-2006, 02:22 PM
MisterCMK's Avatar
Avid Winter Hater
It turns out that the orifice tube was clogged with junk. I guess I didn't do a good enough job flushing out the system when I overhauled the system.
Overcharged AC clthomas 3.7, 3.5 and 3.0 Duratec V6 1 09-30-2015 07:44 AM
recharging ac forkhorn 6.0L Power Stroke Diesel 7 07-18-2015 01:28 PM
A/C blowing cool air..not cold...gauge says overcharged Schuby 1997 - 2003 F150 13 05-10-2014 05:53 PM
1986 F150 overcharging Battery Muddy86F150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 03-26-2010 07:15 PM
over-charging madmader 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-26-2008 05:34 PM
Tags
2000, 97, ac, bleed, extract, f150, f250, ford, freon, overcharge, overcharged, r134a, refrigeration, symptoms, system, taurus, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
