My 95 ford diesel won't idle at all. I checked it with my code reader. The only code it shows is a p0603. I have cleared it off three times. When I start my truck back up and run it a few minutes. I check it and the same code appears. All my friends says to replace the pcm it's bad. Are they a way to check it.
cookie 88. The truck will start but won't idle. Sometimes you can keep the rpm up around 3000 and it will smooth out the a minute or two. It don't smoke know more the it would when it was running good. Now the truck won't pull the hill at my house.
I just changed the fuel filter when this started. The air filter is k&n it is not do yet to be cleaned and reoiled. The oil was changed about 1000 miles ago.
fuel pressure should be 40-60 mine after shimming runs 75psi. also do you ahve a chip installed. p0603 (or is it 605) is normal if you have a chip installed
make sure you are checking your alternator output atleast 2 minutes after starting but not before since the computer does not command the alt. to charge a short time after starting. you will see you volt guage jump up once the alt starts charging. some say this is the glow plugs but its no. cause the glowplug are timed via oil and air temp and the alt won't start charging for the same exact time everytime. so in short if youa re checking alt ouput right after starting it won't be correct.
My alternator is putting out 13.5 now. The truck will start but every light on the instrument panel is staying on. Help !P.S. I have not tested the fill pressure yet but I will.
driver side kick panel under and infront of the parking brake pedal. thats where the somputer is and a chip would be stuck into the back of it facing the driver.
