Electric soft latch
Mike,
I know that GM used tehm in most big luxury cars starting back in the 70's, but th enicer compact units started in the early 80's. The could be found on all of the bigger cars, Cadillacs, Buicks, Pontiac Bonneville's etc. both front FWD and RWD. I don't have any experience with the Ford units or what models to look on.
Good luck with it
Bobby
Good luck with it
Bobby
Mike,
Yes, thats how they work. the trunk lid just has a smiple "u" shaped piece, the latch mechanism is mounted to the car body and grabs hold of the catch and pulls the trunk lid the last couple of inches. I think GM refers to it as an "electric trunk pull down motor"
I don't have any experience with other makes but I'm sure Ford/Lincoln, Jaguar, Mopars, etc all have something similar.
Can't wait to see what you come up with
Bobby
Bobby
Mike,
Are you going to mount in on the firewall? Is there room to mount it inside, under the dash, and have an access hole for the actual latch to come through?
I was wrong about the latch. The pull down motor has the simple "U" shaped piece on the top of it. That actuall latching part is mounted on the trunk lid. It is basically a standard key activated latch with an electric solenoid atached to it so you can open it from the drivers seat.
oops
Bobby
oops
Bobby
I sold many of those deck lid pull down motors and actuators when I worked for Buick a long time ago.
You wouldn't believe how many owners/friends would slam down the deck lid and "oh boy"!
I wonder if you could find them in the auto salvage yards?
mt54, be sure and post some progress pics, if you can.
