Ignition turns and starts truck with no key why?
Old 07-17-2006, 12:40 AM
fordinmudd's Avatar
fordinmudd
fordinmudd is offline
For the last few weeks something with my 95 f 250 (351 w auto) hasent been right with the Ignition.I can turn the ignition without the key in and start my truck why is this?Do i need a new one?..what about the key how do i get a new one made if i need one to fit my key?any info will help..thanks
Old 07-17-2006, 06:50 AM
frederic's Avatar
frederic
frederic is offline
The ignition lock has pins that line up when the key is inserted, allowing the lock to turn (like any lock). When the pins wear out, sometimes you can turn the lock without the key.
replace ignition lock.
Old 07-17-2006, 09:34 AM
Nathane's Avatar
Nathane
Nathane is offline
before it stops working, and strands you...
Been there, done that with my cousins van
Spend the $15 at a junkyard if you have too, but being stranded because the ignition doesnt work absolutly sucks
~Nate
Old 07-17-2006, 02:09 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
Here's some info on how to do it.
http://www.autozone.com/servlet/UiBr...3d800a9e94.jsp
I got a new one from the Ford dealer with a new set of keys for about $14.00 a few years ago. Your new keys will not match the doors, but if you are worried about this(I just carry both keys), you can get a locksmith to make the door locks match the new ignition keys.
Old 07-17-2006, 10:41 PM
thefonz#1's Avatar
thefonz#1
thefonz#1 is offline
Thumbs up
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0a/9e/94/0900823d800a9e94.jsp
It would be easier and cheaper to match ignition cyl to current key.
A locksmith should have an 'uncoded ' ignition cyl. and set it to his key. Or they can use a switch already combinated, overlapping the cuts and giving him a new key but still work doors and ign.
Just find a locksmith that has a walk in shop instead of mobile service only, that way there is no service call[img]images/icons/icon14.gif[/img]
Old 07-17-2006, 10:58 PM
wickymustang's Avatar
wickymustang
wickymustang is offline
Once you get the ignition replaced make sure that you don't have 50 lbs of crap om your key ring, that is what causes the pins to wear out like yours have. Yes, with time from putting the key in and taking it out you will wear the pins down, but its the extra weight on the key ring that ***** the key and accelerates the wear.
Old 07-18-2006, 11:29 PM
fordinmudd's Avatar
fordinmudd
ok so let me get this right i need a new ignition then right?..i did have about 8 keys on my key ring maybe thats to much?but the truck does have alot of miles on it over 200,000 so im sure it was going to go anyway sooner or later.
Old 07-28-2006, 04:28 PM
Bronco Chick's Avatar
Bronco Chick
Bronco Chick is offline
on that year it is a common problem for the "ears" on the ignition to break. when that happens sometimes the ignition cylinder will turn without a key. Go to a locksmith with your key and they will key up a new cylinder to your key. That is the best way to fix it and it's not very expensive.
IslandBlueV10
1999 to 2016 Super Duty
18
11-11-2017 12:56 AM
K A M
2017+ Super Duty
05-01-2017 10:08 PM
avking2508
07-09-2016 06:47 PM
Mad.Scientist
08-26-2009 12:27 PM
cobrarep
08-03-2008 01:13 PM
Quick Reply: Ignition turns and starts truck with no key why?
