Ignition turns and starts truck with no key why? - Ford Truck Enthusiasts Forums
Old 07-17-2006, 01:40 AM
fordinmudd's Avatar
fordinmudd fordinmudd is offline
fordinmudd is starting off with a positive reputation.
For the last few weeks something with my 95 f 250 (351 w auto) hasent been right with the Ignition.I can turn the ignition without the key in and start my truck why is this?Do i need a new one?..what about the key how do i get a new one made if i need one to fit my key?any info will help..thanks
Old 07-17-2006, 07:50 AM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
The ignition lock has pins that line up when the key is inserted, allowing the lock to turn (like any lock). When the pins wear out, sometimes you can turn the lock without the key.
replace ignition lock.
Old 07-17-2006, 10:34 AM
Nathane Nathane is offline
Nathane is starting off with a positive reputation.
Quote:
before it stops working, and strands you...
Been there, done that with my cousins van
Spend the $15 at a junkyard if you have too, but being stranded because the ignition doesnt work absolutly sucks
~Nate
Old 07-17-2006, 03:09 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Here's some info on how to do it.
http://www.autozone.com/servlet/UiBr...3d800a9e94.jsp
I got a new one from the Ford dealer with a new set of keys for about $14.00 a few years ago. Your new keys will not match the doors, but if you are worried about this(I just carry both keys), you can get a locksmith to make the door locks match the new ignition keys.
Old 07-17-2006, 11:41 PM
thefonz#1 thefonz#1 is offline
thefonz#1 is starting off with a positive reputation.
Thumbs up
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0a/9e/94/0900823d800a9e94.jsp
It would be easier and cheaper to match ignition cyl to current key.
A locksmith should have an 'uncoded ' ignition cyl. and set it to his key. Or they can use a switch already combinated, overlapping the cuts and giving him a new key but still work doors and ign.
Just find a locksmith that has a walk in shop instead of mobile service only, that way there is no service call[img]images/icons/icon14.gif[/img]
Old 07-17-2006, 11:58 PM
wickymustang wickymustang is offline
wickymustang is starting off with a positive reputation.
Once you get the ignition replaced make sure that you don't have 50 lbs of crap om your key ring, that is what causes the pins to wear out like yours have. Yes, with time from putting the key in and taking it out you will wear the pins down, but its the extra weight on the key ring that ***** the key and accelerates the wear.
Old 07-19-2006, 12:29 AM
fordinmudd's Avatar
ok so let me get this right i need a new ignition then right?..i did have about 8 keys on my key ring maybe thats to much?but the truck does have alot of miles on it over 200,000 so im sure it was going to go anyway sooner or later.
Old 07-28-2006, 05:28 PM
Bronco Chick Bronco Chick is offline
Bronco Chick is starting off with a positive reputation.
on that year it is a common problem for the "ears" on the ignition to break. when that happens sometimes the ignition cylinder will turn without a key. Go to a locksmith with your key and they will key up a new cylinder to your key. That is the best way to fix it and it's not very expensive.
1996 Ford 350 Starter engages on first click of key avking2508 1987 - 1996 F150 & Larger F-Series Trucks 5 07-09-2016 07:47 PM
2 vehicles use 1 key? IslandBlueV10 1999 to 2016 Super Duty 17 05-04-2016 01:56 PM
PATS Ignition Key Programing Question banshee_man_96 Excursion - King of SUVs 45 10-25-2014 12:27 PM
my ignition isn't wanting to turn fscarrow 1999 - 2003 7.3L Power Stroke Diesel 8 08-15-2014 07:00 PM
2004 F150 key/ignition problem texasag00 2004 - 2008 F150 1 05-20-2012 03:28 PM
Tags
91, cylinder, f150, f250, ford, ignition, key, keys, lock, start, started, starts, switch, truck, turn, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
