Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-16-2006, 09:39 PM
loosecannon39 loosecannon39 is offline
Garage is empty, add now
loosecannon39 is starting off with a positive reputation.
Question head swap
hey folks,
its loosecannon with a 2 part question. will the earlier 24 bolt heads with center water outlets bolt on the later engines that came with the front outlets?? if so, what do you do about the thermostats?? thinking of adapting a later model HEI distributor , and i heard that the dist caps are so large,
that they hit the water outlets on the later engines????
TKD
DAN
  #2 (permalink)
Old 07-16-2006, 10:54 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Hey there Dan,
Sounds like you're thinking about a project. You might check out the MSN groups forum for Ford flathead 1932 to 1953. They have all kinds of info archived in the techno site on the left margin of the page.
http://groups.msn.com/FordFlathead19...3/general.msnw
Basic answer to your question is they do bolt on, but it's not a simple swap. There are a couple of contrary coolant holes that don't line up. You end up plugging one or two. I've read about it, but haven't messed with it.
The early heads have seen some pretty creative thermostat solutions, basically what the guys that run early engines have to do anyway. Everything from capturing the rim with screws thru the neck to using zip ties above and below a t-stat in the hose close to the head. This too, is covered in the Techno site notes.
Lots of guys are running HEI systems with late heads. Another similar option is to go with MSD setup that is made for the 8RT/8BA engines. Only advantage to a modified HEI from GM is cost savings. Techno notes cover this topic also. You'll find super flathead guys on that site.
Tim
Tags
flathead, ford, head, interchange
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
