Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-02-1999, 09:15 PM
Fordnut Fordnut is offline
Fordnut is starting off with a positive reputation.
Painting raised letters
I am restoring a 1970 F100 and am working on the interior. There are raised letters on the vents and temperature controls and I was wondering if anyone had any tricks for painting these letters?
  #2 (permalink)
Old 06-03-1999, 12:40 AM
Like M. Fords's Avatar
Like M. Fords Like M. Fords is offline
Like M. Fords is starting off with a positive reputation.
You need to be careful in the type of paint you use. The raised letters you describe are also lighted in the same circut as the dash and instrument lights. If you paint them with the wrong paint or too heavy, they will not glow at night. Some paints, even white, have ultra fine particles of metal in them and are not transparent. They are painted white at the factory; possibly with the same type of paint used to frost outdoor Christmas lights? I don't know. Try it on a small spot first (the tiny dots on the fan speed control) before painting all the letters. Let the paint dry and see if they still light up in the dark when you turn your headlights on.Find out if the plastic pieces can be removed from the bezel---they appear to me to be seperate parts, but I could be wrong. Then dampen a piece of paper with the paint on a flat surface and stamp the plastic pieces on the wet paper. Only the highest flats of the letters will get the paint. If you can not remove the lettered pieces from the bezel, then I guess you will have to find a very small brush and a very steady hand.Good Luck!
__________________
"I see," said the blind man to his deaf daughter.
  #3 (permalink)
Old 06-03-1999, 11:58 PM
Thanks for the information. It seems that I was going to go about it the wrong way. I appreciate your help and will try what you suggested.
Thanks again
  #4 (permalink)
Old 06-04-1999, 04:05 PM
__________________
  #5 (permalink)
Old 01-07-2006, 08:58 PM
MAX68 MAX68 is offline
MAX68 is starting off with a positive reputation.
Use A Q-tip, Do Not Keep Using The Same One Though
Swap Them Out
  #6 (permalink)
Old 01-08-2006, 10:35 AM
DarkWolf40's Avatar
DarkWolf40 DarkWolf40 is offline
DarkWolf40 is starting off with a positive reputation.
What about painting chrome trim pieces such as a "Custome Cab" badge thats on the side of the cab. It has red paint on the indsied portion. What kind of paint would work and stick to the chrome and then actually hold up to sun and weather?
  #7 (permalink)
Old 01-08-2006, 04:23 PM
well i used auto paint, with a little extra hardner. then i rubed the emblem against a piece of 400 wet/dry paper on a really flat surface until all unwanted paint was gone
let the emblem dry for a couple of days ,though
this worked for me
  #8 (permalink)
Old 01-08-2006, 06:25 PM
DarkWolf40's Avatar
Did you use a self etching primer then?
  #9 (permalink)
Old 01-08-2006, 10:31 PM
Darkwolf40
Yes, Now For The Small Figures In The Center I Took My Time With A Very Small Piece Of 400(wet) And Rub Till The Figures Where Nice
Remember You Caint Make Old New..
Good Luck
  #10 (permalink)
Old 01-09-2006, 08:20 AM
ceetwarrior's Avatar
ceetwarrior ceetwarrior is offline
ceetwarrior is starting off with a positive reputation.
Darkwolf, if the emblem is a '70 then I believe the paint should be black, with a C8??? part number.
Any good paint will work fine. I spray all of mine, they look mint. No primer either.
__________________
-There's no replacement for Displacement
  #11 (permalink)
Old 01-09-2006, 04:56 PM
limegoldf100 limegoldf100 is offline
limegoldf100 is starting off with a positive reputation.
Actually, if the truck is an original 1970 model, it won't have the Custom Cab emblems. If it's a Styleside, the bedside near the rear will have the Custom, Sport Custom, Ranger, etc. designation. The Custom Cab emblem was discontinued after 1969.
  #12 (permalink)
Old 01-09-2006, 07:24 PM
Mine Was Black Inside And A 68
These Emblems Stopped After 69
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
