Anyone running bypass oil filter setups?
I did some reading on bypass filters a while ago and thought it sounded like a pretty good idea, so I thought I'd make a post to see if anyone here is running one, and what their experiences are.
I saw where someone is actually using toilet paper for filter cartidges?!?
I just put on the Amsoil dual bypass oil fiter, but don't have any results yet. The bypass does filter down to 2 micron so I don't see how that can be a bad thing! The toilet paper rool filter is a real product here: http://www.bypassfilter.com/MotorGuardFilters.htm and they have been used for decades.
I run the Oil Guard EPS-20-PSD-73L, 1 micron filtration, by-pass filter system. It comes with all of the fittings, hose, brakect, and insturctions. Easy installation, good directions (even color pictures).
They are a Site Sponsor and right now they are on sale for 10% off ($187.20) through the 15th of July.
http://community.webshots.com/photo/...52930862tMiVoe
(Hit "Next" in uppper right hand corner)
where are you in N. IL?
I and a few other SD owners are in the far west burbs!
I bought a bypass filter setup from Tymar. I've only had it on for about 2,500 miles.
So far -
Stock power setting, no bypass filter - engine oil stayed clean up to about 3,000 miles, then started getting dark.
DP Tuner 40hp/80hp mixed usage, no bypass filter - engine oil started getting dark by 500 miles. By 3,000 miles, oil was very dark gray, though not as black as oil from a bigrig - or the oil from my brother's Cat 3208 powered truck.
DP Tuner 40hp/80hp mixed usage with bypass filter - at 2,500 miles, the Schaeffer oil is still about as green as when I poured it out of the bottle - there is only the slightest hint of gray to it.
In 500 miles, I'm going to replace the bypass filter and send a sample of oil to Blackstone. Then I will really know how well it is working.
So far -
