89 Bronco II ignition switch - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 07-16-2006, 08:31 AM
Avanti Avanti is offline
Avanti is starting off with a positive reputation.
Where are the retaining screws for an 89 or 90 Bronco II ignition switch? The 88 & earlier B II"s are different. A picture would help. I asked this question months ago but got answers for an 88 and earlier. Chilton says remove the retaining screws from the studs.
Old 07-17-2006, 05:54 PM
cylinder lock pin
Also where is the cylinder lock pin located ? I need to replace the key cylinder. I pulled every thing off & can not find the hole to push in a 1/8 inch drill bit to release the lock cylinder.
Old 07-18-2006, 12:07 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Hi,
This is one of the various threads on this. I believe this will help
http://www.ford-trucks.com/forums/sh...ition+lock+pin
Don't believe everything you read in any manual, especially a Chilton's. No BII/Ranger I have worked on has retaining screws.
Old 07-19-2006, 05:55 PM
Ignition lock replaced
Found the pin & replaced the lock on my 98 BII with tilt wheel & auto trans. Used a bent 6 inch 14 gauge copper wire to push in the pin to release the lock. You insert it through the tube like flange that points down & to the cars rear below the lock cylinder. You canít see the hole but I used the wire to feel around. It only took a few seconds. Also you do not have to pull the steering wheel. Tilt the wheel up. Pull the lower dash panel below the column that is held by 2 screws. Than remove the 2 screw holding the upper & lower steering plastic shroud. Remove the lower shroud. Push it forward & release from the grooves on the upper shroud. Than tilt the wheel down & pull off the top shroud. Maybe this will help someone else.
88 Bronco II will not start. Ayylmao Bronco II 4 07-09-2016 04:11 PM
88 bronco II clutch rob188 Bronco II 11 05-02-2009 06:37 PM
Replacing ignition switch Avanti Bronco II 9 06-03-2006 05:11 PM
89 Bronco II Towing spazzbear Bronco II 5 04-09-2003 02:36 PM
Meyer snowplow on 1990 Bronco II rbluhm Bronco II 2 12-11-2001 07:24 AM
Tags
1989, 89, bronci, bronco, change, cylinder, drill, ignition, ii, illustration, ingnition, lock, pinout, remove, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
