help
Any modifications to your truck?
When you say it won't crank do you mean it won't turn over at all or it turns over but will not start?
Does it show a check engine light?
If it turns over but does not fire check the fuses in the block on the driver side inner fender under the hood. #22 is the fuse for the fuel heater which also supplies the PCM. If it is blown, there is a plug on the side of the fuel filter housing (under the hood looking thing on top of the engine, you will have to remove it for this). Unplug, replace the #22 fuse and try it again.
Dave / Believer45
Dave / Believer45
