1969 F250 wiring - Ford Truck Enthusiasts Forums
1969 F250 wiring
Old 07-02-1999, 03:37 PM
ron minor ron minor is offline
ron minor is starting off with a positive reputation.
1969 F250 wiring
I just got a 69 F250 that I am trying to restore the first problem I am having is the wiring harness I have been able to get all the lights working again except for the front emergency flashers. Does anyone have a wiring diagram or know where I can get one? I have looked in the ads area and none list this year is it the same as the 65-67 wiring harness?? If anyone knows how it should be wired that would help also.
Old 07-13-1999, 07:43 AM
Stock Man
Guest
Posts: n/a
1969 F250 wiring
Ron:
Most problems with wiring stem from obvious damage to the harness, poor connections at the terminal ends, corrosion, or poor ground. I am assuming that your harness hasn't been cobbed. If so I would recommend you change it. The front harnesses easily uncouple on the inside of yuor truck just beyond where they go through the firewall into the cab under the dash. You should be able to find a complete front harness at a scrap yard. If your harness looks o.k. then pull it out and perform a continuity test for each of the wires. An ohmeter works great and will show if there is any hidden breaks or corrosion under the casing. These are problems that may not be easily spotted by eye. I hope this helps.
Stock Man
1967 Galaxie 500 Convertible (I need factory rims)
1967 F-250 FE 390 4wd
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old 07-13-1999, 09:48 AM
ray ray is offline
ray is starting off with a positive reputation.
1969 F250 wiring
1990 glow plug wiring harness connector mtnchap Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 05-11-2015 11:36 PM
wiring harness question Michael Manglos Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 02-08-2014 11:22 PM
Towing Lights Wiring Harness Finally Powerstrokin 1999 - 2003 7.3L Power Stroke Diesel 12 02-08-2013 10:11 PM
1978 f250 Radio Wire Harness Question 78fourby4f250 1973 - 1979 F-100 & Larger F-Series Trucks 13 06-06-2012 07:30 AM
buy wiring harness 85 f250 with 460 carbed motor? honeyb 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-03-2009 10:22 PM
Tags
1967, 1969, 250, 69, diagram, diagrams, f250, ford, fuel, harness, kit, spec, truck, wireharness, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
