speedometer gear
Old 07-13-1999, 11:29 AM
frog's Avatar
frog
frog is offline
speedometer gear
Does any one know where I could get the little gear that is on the tranny end of the speedometer cable. I'm in Germany and will have to order this online. thanks. Jesse
Old 07-13-1999, 12:36 PM
Stock Man
Guest
Posts: n/a
speedometer gear
There are many different gears that were used and it all depends on the year and model of your truck as well as whether or not it still has its original components, such as rear axle, transmission and tire size. The wrong gear will result in your speedometer reporting the rate of travel incorrectly. If you post more data maybe I or someone else might be able to determine the correct part no. for you.
Stock Man
1967 Galaxie 500 convertible (I need factory rims)
1967 F-250 FE 390 4wd
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old 07-14-1999, 07:32 AM
Steve Heidt
Guest
Posts: n/a
speedometer gear
f.100
07-18-2010 03:16 PM
wyazel1
37
08-22-2008 06:16 PM
jesse460
09-25-2002 06:31 AM
jesse
11-20-1999 08:45 PM
jesse
08-05-1999 05:13 AM
Quick Reply: speedometer gear
