A/C Spring Lock Coupling-Cannot get Apart-Help ! - Ford Truck Enthusiasts Forums
Old 07-15-2006, 01:35 PM
michael71 michael71 is offline
michael71 is starting off with a positive reputation.
I am changing out my A/Compressor, etc on my Ford Truck. I cannot get one of the A/Cl lines loose at the "spring lock coupling". I have the proper spring lock coupling tool and all but this one came loose fairly easy. I have sprayed the area with WD 40 and penetrating oil but cannot get the lines loose. Anybody got any ideas? I have never had this happen before. The coupling does not look damaged.
Thanks...
Old 07-15-2006, 06:55 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
See you on the boards. .
Old 07-15-2006, 07:10 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Twisting while pulling usually is the answer. Make certain you have one of the OEM type tools. They fully enclose the coupler plus give you something to hold onto while you push the sleeve portion into the springlock.
PB Blaster helps to loosen it up first. WD40 is pretty worthless.
Steve
Old 07-15-2006, 08:39 PM
lsrx101 lsrx101 is offline
lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.
These are the ones Steve is talking about:
http://makeashorterlink.com/?A11C2596D
May I ask why you are replacing the compressor?
Old 07-15-2006, 09:50 PM
Yes, this is the type of spring lock tools I use. I have 2 sets. I have worked all day at trying to get this one coupling loose. All the others came apart. This one is not corroded nor beat up. I have taken the low pressure line loose at one end so I can twist it at the other end at the coupling while trying to get it apart. The spring inside the coupling looks ok. Not bent or corroded. If I took a hooked awl and pulled the spring out, would that release the coupling?
I am replacing the compressor as the clutch burnt up and new clutch was almost as much as a complete compressor. Thanks for any suggestions.
Old 07-16-2006, 01:22 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
I got a metal Napa one that works very well. I have not had good luck with the plastic ones.
Good luck.
Old 07-16-2006, 03:15 PM
Thanks to all for the info. I finally went and found a metal spring lock tool and the coupling came right loose. I do not know why the plastic would not work on this coupling. The plastic worked fine on all the others. Anyway, problem solved and thanks to all.
Mike
1982 F250 Parking Brake Parts Missing jeremiah.d.rathbun 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 10-04-2016 04:41 PM
2005 F250 Brake problem gatorglenn Brakes, Steering, Suspension, Tires, & Wheels 1 05-07-2015 01:36 PM
Align leaf spring pin with axle shaft PapaMatt 1961 - 1966 F-100 & Larger F-Series Trucks 9 04-01-2015 08:33 PM
Ford Truck Door latch stuck cbasye 1987 - 1996 F150 & Larger F-Series Trucks 6 06-29-2014 09:14 PM
Too much camber Raul Brakes, Steering, Suspension, Tires, & Wheels 14 05-11-2002 10:42 PM
Tags
ac, compressor, coupling, couplings, ford, lock, loose, repair, spring, tool, tools, undo, work, working, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
