Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-15-2006, 12:18 AM
kw5413's Avatar
kw5413 kw5413 is offline
kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation.
Particulate Filter Info
For a really good write up on the new particulate filters read this article from AutoWeek:
http://www.autoweek.com/apps/pbcs.dll/article?AID=/20060714/FREE/60710004&SearchID=732507777206
__________________
"There is a fine line between fishing... and just standing on the shore looking like an idiot"
  #2 (permalink)
Old 07-15-2006, 12:09 PM
bf250's Avatar
bf250 bf250 is offline
bf250 is a splendid one to behold bf250 is a splendid one to behold bf250 is a splendid one to behold bf250 is a splendid one to behold bf250 is a splendid one to behold bf250 is a splendid one to behold bf250 is a splendid one to behold
i wonder what the warranty will be on this thing.
__________________
current ride - 2003 explorer, 4x4, v8
ford trucks i have previously owned
1972 f250 1989 f250
1995 f350 2004 f250
2006 f250
will get a truck again!
  #3 (permalink)
Old 07-15-2006, 08:03 PM
kw5413's Avatar
"The first filters had to be taken off and cleaned at around 80,000 miles. But the filters coming in January for U.S. diesels are designed to last the life of the vehicle without any extraordinary maintenance."
Yeah, I wonder if they will back that up. In any case it is emissions so whatever they make the standard emissions warranty I would think that would be included.
__________________
  #4 (permalink)
Old 07-15-2006, 08:54 PM
A. Michael Foxtrot's Avatar
A. Michael Foxtrot A. Michael Foxtrot is offline
A. Michael Foxtrot is starting off with a positive reputation.
I agree, any EPA mandated emission control items would have to be covered under federal law.
In case of something like this, I would imagine that this would fall under "Major emission-control components" and would fall under the 8/80 warranty.
__________________
(Cheap, Fast, Reliable...Pick any two)
1998 F-150 S/C XLT 4X4 4.6
2005 F-350 C/C Lariat 4X4 6.0
Click me to see what I drive
  #5 (permalink)
Old 07-18-2006, 07:13 PM
Customz's Avatar
Customz Customz is offline
Customz has a good reputation on FTE. Customz has a good reputation on FTE. Customz has a good reputation on FTE.
wow, i sure hope as well as it says it does. No wonder the new 6.4 will need 375hp just to move the truck.
Imagine this thing with the DPF, EGR, CAT and muffler removed...then you gotta get the electronics talking again.
__________________
2006 F-250
  #6 (permalink)
Old 07-26-2006, 09:32 AM
kw5413's Avatar
Well, Not sure this will fly with Admin., but I think it is Sticky time for this Particulate Filter info.
__________________
  #7 (permalink)
Old 08-03-2006, 04:37 PM
03f2506.0 03f2506.0 is offline
03f2506.0 is starting off with a positive reputation.
Dpf
The Autoweek artical stated that when backpressure built up the engine will dump more fuel. What will that do to EGT's, will they be to high and cook the turbo?
__________________
2003 F-250 Lariat SC SB 6.0, Torqshift, Truck build date: 1/29/03, engine build date: 1/8/03. Warn front receiver, Spray-in bedliner, Leer cap, A pilar boost, egt & trans temp gauges plus water temp,volts & fuel pressure. 250W oil pan heater, Marinco plug, Fumoto valve. High idle mod.
Replaced:4 injectors, 2 VGT solenoids, EGR, EBP, MAP & 2 turbos
  #8 (permalink)
Old 08-03-2006, 04:43 PM
phtank phtank is offline
phtank is starting off with a positive reputation.
Well, here in California that probably means mandatory "smog checks" for 08+ diesels. I'm glad I have on 06 (smog exempt).
  #9 (permalink)
Old 08-14-2006, 11:46 PM
bnmccoy's Avatar
bnmccoy bnmccoy is offline
bnmccoy is starting off with a positive reputation.
Couple of links regarding diesel AUDI race car winning with particulate filter
http://www.dieselforum.org/newsarticle/article/443/42/
http://automotive.dow.com/automotive/downloads/presskit.htm
and a old post about Tenneco getting the contract for particulate filters
http://www.ford-trucks.com/forums/354098-2006-or-2007-model-ford-diesel-exhaust.html?highlight=particulate
__________________
08 F350; DRW; 8' Bed; 4.10LS; 4x4; 6.4 PSD; TorqShift; Wide Track Front Axle; Lariat Crew Cab
07 Montego Bay 34RLB3 5th wheel
(traded the 06 w/ 45Kmi. 10/1/07)
(traded the 04 w/ 56Kmi. 3/25/06) N5BUJ
  #10 (permalink)
Old 08-21-2006, 06:26 PM
mxracer2387 mxracer2387 is offline
mxracer2387 is starting off with a positive reputation.
I wonder how this will effect aftermarket exhaust mods... is it located like a catalytic converter would be, or somewhere else in the exhaust, no point in a 4 inch downpipe if you have a constriction half way down... Has anyone heard if California is going to go to smog every 2 years on diesels like they do on gasoline powered cars.
  #11 (permalink)
Old 08-22-2006, 06:48 AM
IB Tim's Avatar
IB Tim IB Tim is offline
Administrator
IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation
Go for it Keith~
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
  #12 (permalink)
Old 08-23-2006, 02:12 PM
cc1999 cc1999 is offline
cc1999 is starting off with a positive reputation.
Does anyone know if all this emmisions crap is going to be tied into the computor. Like on the jeep CDI I had last year it had converters and such under it but they were not tied into the electronics.
  #13 (permalink)
Old 10-02-2006, 08:05 PM
CaptainCummins CaptainCummins is offline
CaptainCummins is starting off with a positive reputation.
Cool
2007 is the end of diesel performance as we know it. Particulate Filters and such are tied in to the ECM through all sorts of sensors. For example, the new 6.7 liter Cummins will have over 10,000 ECM parameters. On the Cummins the muffler is removable, but turboback exhaust is a thing of the past. You will not be able to "fool" the ECM with chips, tuners, and other devices of the sort because in short, you will fry the emissions system. If you do remove this equipment, the CEL will be illuminated and there will be no way to shut it off. If they do come up with a tuner, there will be no doubt it will cost big $$$. They would have to have a harness going to every single sensor on the truck. Extra fuel will be injected on the exhaust stroke to keep the Particulate Filter "fired up".
In short, after ULSD motors come out, you will be able to make them loud, but not more powerful
  #14 (permalink)
Old 10-17-2006, 02:17 PM
bubahyde bubahyde is offline
bubahyde is starting off with a positive reputation.
There is a lot of truth to that, except you won't even be able to make it loud. The DPF is soooo resrictive that "@#$!%^! *&^%*$" has desided to eliminate the muffler entirely. NO NEED. Fact is HEAT is the main consern. Exhaust exit temps are VERY VERY HOT during regeneration. Wait till you see the FUNKY exhaust tip used to cool the exhaust.
  #15 (permalink)
Old 10-17-2006, 02:26 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation
OH I can't wait for the lawsuits on burning down grasslands caused by the particulate filters. Farmers are exempt from having cats on gas powered trucks because of this (in many states not all by any stretch) so how many fields and wildfires are going to be started by these and with no way to remove them farmers are just not going to be able to drive thier trucks across grassland areas or hayfields or wheat stubble fields because they will cause fires just like the cats did when they first came out. Oh well I guess farmers don't buy very many diesel pickups anywaySmileyCentral.com
__________________
Rob
Dying's not so bad
It's living that will kill you off
Tags
64 , 67 , 73 , bypass , california , clean , cummins , exempt , filter , filters , ford , liter , particle , particulate , remove , smog
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
