fuel tank
I seen in the other posts that some guys will drive the rear wheel up on a block to rase the filler up higher or pull the inner vent tube out of the filler hose
this is the best thing i have done is get a fuel restantet plastic 3/4 to 5/8 barbed 90 , 4 ft 5/8 fuel hose and a brass 5/8 barbed 90. then remove the roll over valve from the top of the tank, stick the 3/4 90 in the gromet on the tank. remove the filler from the truck, drill a 5/8 hole in the filler neck in a spot that is higher than the pump nozzel when inserted in the filler neck. braze the brass 90 to the filler neck, remove the inner hose from the filler. replace the filler neck on the truck and connect the 2 90s with the new 5/8 hose
tkisling
12-25-2013 09:47 AM
bluesman2333
13
02-03-2008 08:15 AM
swhite005
08-03-2005 12:54 PM
87f150xlt
15
11-09-2004 12:19 AM
