Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Georgia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
Closed Thread
  #1 (permalink)
Old 07-14-2006, 09:58 AM
FTE Jason's Avatar
FTE Jason FTE Jason is offline
Site Administrator
Garage is empty, add now
FTE Jason is a splendid one to beholdFTE Jason is a splendid one to beholdFTE Jason is a splendid one to beholdFTE Jason is a splendid one to beholdFTE Jason is a splendid one to beholdFTE Jason is a splendid one to beholdFTE Jason is a splendid one to behold
Talking Free Tuner!!!!
I need someone to swing by the office and pick up a Sniper Tuner, all we would ask is you bring me a 6 pack of beer, nah just joking, (Heinken cough)
Seriously though the only request we would have is that you do an installation article on the item and a good write up with your feedback and the tuner is all yours.
Here is some more info on the Sniper
<!--StartFragment -->
  • 3 power levels For Diesel Applications. Switch between 50HP, 75HP, and 100HP with a quick and easy to use software developed by sniper tuning.
  • The Special Forces kit consists of: tuning software, Interface flash box, OBD-II cable, USB cable & instruction manual.
  • Customer requirements: IBM based PC (laptop or desktop) with Windows XP.
  • Fully Programmable Software lets you control the settings right down to the T. Gives you complete freedom to program your vehicle the exact way you want it.
  • The Special Forces allows you to program 2 vehicles!
  • 5 Files can be loaded on the interface at one time, aslo Interface can store truck & car performance files at same time.
  • Diesel Special Forces Kit give you the freedom to Adjust to your own specifications at anytime. Snipers kit allows you to raise the speed limiter, transmission firmness, shift points, converter lockup, adjustement for throttle response control, nos or propane, smoke control limiter, aftermarket injectors, and injection timing.
  • Gas Special Foces Kit gives you the freedom to adjust Compression Ratio, Fan Settings, engine idle speed, Passive anti Theft, fuel octane rating, ehaust/headers, Oxygen sensor deletion, shift points, shift firmess, rev limiter, speed limiter, tire height, gear ratio, air fuel ratio, spark advance, supercharger, turbocharger, nitrous, injector size, returnless fuel pressure setting, mass air brand, calibration, intercooler type, fuel pump type.
  • Unlimited Files can be created to store your favorite settings.
Gas Powered Special Forces Include These Ranges Of adjustability:
-Compression ratio -Supercharger (Roots & Centrifugal
-Low / High fan settings -Turbocharger
-Engine idle speed -Nitrous (wet & dry)
-Passive Anti Theft -Injector size
-Fuel Octane rating -Returnless fuel pressure setting
-Headers / exhaust -Mass Air brand / calibration
-H / x pipe -Intercooler type
-Rear oxygen sensor delete -Fuel pump type
-Trans shift points -Unlimited number of files can be created
-Trans shift firmness -Engine rev limiter
-Engine speed limiter -Tire height / speedo correction
-Gear ratio / speedo correction -Air Fuel Ratio adjustments (richen/lean)
-Spark advance (+/-)
DIESEL Special Forces offers a wide range of adjustability:
-3 levels of power (50, 75, & 100)
-speed limiter -adjustment for NOS & Propane
-trans firmness** - adjustment for smoke control limiter
-trans shift points** -adjustment for aftermarket injectors (single shot & split shot)
-converter lockup** -adjustment to Injection timing
-adjustment for throttle response control
-Programming time 30 seconds***
** currently available for 7.3 liter only.
Call me with any questions please refer to the Sniper when you call.
678-218-4337x105 Jay
__________________
FTE Sales & Marketing
See the site sponsor list in the "Shop" drop down menu.
2007 F150
Bully Dog Triple Dog Gas Downloader
Volant Performance Cold Air Intake Kit
Volant Performance Exhaust System
Volant Performance Ram Air Scoop
Brand Motion iPod Docking Station
Rough Country Leveling Kit
  #2 (permalink)
Old 07-27-2006, 08:31 PM
Menroid's Avatar
Menroid Menroid is offline
1979 Ford F-250
Menroid is starting off with a positive reputation.
I can't believe no one has taken you up on the offer, or have they? I am in SE GA, probably not where I can run by and pick it up.
  #3 (permalink)
Old 07-28-2006, 08:01 AM
FTE Jason's Avatar
Site Administrator
Thanks for the interest but I sent it out earlier in the week, I will keep you in mind in the future, we have lots of goodies we are going to start giving away, keep and eye out on the boards....
JAY
__________________
2007 F150
Closed Thread
Tags
73, f150, forces, ford, free, ii, lean, manual, obd, psd, shift, sniper, software, special, truck, tuner, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
