F250 351W Belt Routing - Ford Truck Enthusiasts Forums
Old 07-13-2006, 09:41 PM
jerseyf250 jerseyf250 is offline
jerseyf250 is starting off with a positive reputation.
I almost the motor back together but ran into an issue with the belt. Does anyone have a diagram or a pic of the belt routing? 1988 F250 351W
AC, PS, and smog pump.
Thanks.
Old 07-14-2006, 09:08 AM
I double checked the pullies and accessory mounting and everything looks good. Cant figure out why the belt is short. reassembly by memory sucks.
Old 07-14-2006, 10:56 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Is this belt off a 351 or 302?
Old 07-14-2006, 11:04 AM
JoeVB's Avatar
JoeVB JoeVB is offline
JoeVB is starting off with a positive reputation.
Here is the diagram from my 95 F250, 351W...my 92 F150, 351W has the same diagram.
Old 07-14-2006, 08:07 PM
That did the trick. Thanks for the diagram.
351W Drive Belt problem Nigma Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 07-06-2016 06:12 PM
belt diagram Fitzgerald_welding 1987 - 1996 F150 & Larger F-Series Trucks 11 03-15-2016 05:19 PM
1995 f250 351 W delet the smog pump cod105ey 1987 - 1996 F150 & Larger F-Series Trucks 16 02-11-2011 08:35 AM
serpentine belt routing black cloud 6.0L Power Stroke Diesel 2 10-19-2010 10:45 AM
Removing smog pump from 96 F250 351W 93'colttsi 1987 - 1996 F150 & Larger F-Series Trucks 4 06-30-2008 09:04 PM
Tags
1990, 1996, 2006, 351, 351w, 95, 96, belt, diagram, f150, f250, fan, ford, routing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
