Blinking Transmission Control Indicator Light
Not always will it show a code. Mine is doing the same thing the OD light will blink but it is not showing any code at all. Chances are your system is OBDI like mine I have a 97 F250HD if that is the case good luck. Mine has been in the shop a couple of times already and they cant get it to give them a code.
If it is bothering you disconnect the Neg terminal and it will clear the problem. So far I believe that I have it traced down to either the TPS or the VSS sensors.
Resendiz
02-17-2017 04:58 PM
acom01
05-27-2010 07:46 AM
