1998 Ford Explorer Front Axle Whine - Ford Truck Enthusiasts Forums
Old 07-13-2006, 12:17 PM
bp8167 bp8167 is offline
bp8167 is starting off with a positive reputation.
I just replaced both speed sensors and the shift motor on the transfer case in my 1998 Explorer - Eddie Bauer edition / Auto Trac / 4 wheel hi and lo.
I replaced them because both lights (4h/4l) would flash simultaneously 6 times, go out then flash again repeatedly. The mechanic at the Ford Dealer said it was either the speed sensors or the transfer case motor. Rather than fix one thing then it be the other I just changed both sensors and the motor.
Right after I changed the motor and sensor my Explorere developed a whining noise from the front end, which sound like it is coming from the driver's side.
Has this happened to anyone else? What did you find out to be the problem and how did you fix it?
Old 08-01-2006, 04:58 PM
amish77's Avatar
amish77 amish77 is offline
amish77 is starting off with a positive reputation.
might be the hub in the drivver's side front. That's the only 4wd component that I can think of that's there. Other than that I'd think this is an unrelated problem and start troubleshooting steering and suspension.
Old 04-19-2007, 06:47 PM
Surfcop's Avatar
Surfcop Surfcop is offline
Surfcop is starting off with a positive reputation.
CV Joint
My 98 Mountaineer had that noise and it turned out to be a broken CV joint in the front driveshaft where it enters the transfer case. Check it by listing front wheels and rotating front driveshaft. The shaft shouldn't rotate seperately from the CV joint.
Old 06-24-2007, 09:09 PM
andzia andzia is offline
andzia is starting off with a positive reputation.
Quote:
Are you talking about the UNIVERSAL JOINT?
CV joint is on CV axle (goes from front differential to the wheel).
Universal joints are located on the shaft and that one goes from the transfer case to the differential.
Thanks for your time.
BTW I have the same problem, so could you let me know if that's the case?
Old 06-25-2007, 09:51 AM
Surfcop's Avatar
Actually, a constant velocity joint can be anywhere they need it to be. My driveshaft has a u-joint on one end and a CV joint on the other end.
Old 06-26-2007, 05:08 PM
Hi, sorry Ididn't notice that before and yes you right!
How much did it cost you to fix it?
Old 06-27-2007, 10:37 AM
amish77's Avatar
Depends on where you source parts from. Look at The major chain stores first, if they don't have it then you've got to choose between the stealer and the junkyard.
Old 06-28-2007, 01:14 AM
They have it at the Parts America, little pricey (somewhere around 260$ plus core).
Will have to check some other places!
If you guys have any suggestions, please be my guest.
Thanks in advance!
4x4 issues mikekam Expedition & Navigator 1 02-20-2014 11:02 PM
A4wd light flashing on 1998 Expy dakota23 Expedition & Navigator 11 11-19-2013 12:05 AM
02 Explorer 4x4 light flashing lovemy150's Explorer, Sport Trac, Mountaineer & Aviator 1 07-05-2007 02:41 PM
AWD/4WH/4WL Selector Switch amkazen Expedition & Navigator 9 09-03-2005 03:17 PM
"98" Explorer making scary noise. cablecowboy Explorer, Sport Trac, Mountaineer & Aviator 7 03-22-2001 10:27 PM
Tags
1998, axle, end, explorer, ford, front, mountaineer, noise, whine, whining
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
