diff. in rear ends
diff. in rear ends
It seems to me that Ford used a Galaxie rear end in the F trucks up to 72. The 73 and up rearend housing is 4 inches wider. The center sections will interchange without trouble. I believe I've read about different depths of center sections but if you stay with a truck gearset you shouldn't have trouble. I'm currently checking to see if the spring mounts will fit from a 73-9 back to a 67-72 frame so I can put the wider rearend in my 68.
diff. in rear ends
Yes, 9 inch rears have been around since 1957 (at least in F series trucks). The only difference would be if you have a Dana 60 rear, as some F-100's did have a Dana 60 with a 5 bolt wheel pattern. My friends 65' F-100 is set up with a Dana 60, and so I wouldn't know why they wouldn't have continued to do the same thing up into the 1970's.
tractormanbill
22
10-02-2014 02:29 PM
72sleeper
06-24-2013 06:48 AM
