Transmission Identification????
Okay, I've been doing some research and I can't seem to figure out what I have in my 68 F100. I've looked at both sides and this what I have seen.
On the Driver side of the tranny case there is a metal tag that is about two and a half inches wide and about a quater of an inch tall. It has this number on it: 1X3X58 or 1X3X68 not sure if it's a 5 or 6 for sure. That's all the markings I see.
On the Passenger side of the tranny case the following number is stamped into the case: C-93691-S
Under than is an: A 3
That's all the markings I see as it's in the truck and I dont want to drop it if I dont need to. It has a Dana 21 married to it. I need to figure out what I have so I know the grear ratios and such also, so I can figure out what transfer cases might work as the Dana 21 is a high only transfer case. I want to swap it out for a High-Low transfer case.
Any help would be greatly appreciated.
This link may help if you have a manual trans http://www.novak-adapt.com/knowledge...on_gateway.htm
zerfetzen
114
07-28-2022 03:38 AM
bulletpruf
1999 to 2016 Super Duty
03-10-2020 01:09 AM
RMPC
32
04-29-2019 06:20 PM
frank washington
11-07-2016 10:44 PM
