Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-12-2006, 09:03 AM
Psyte Psyte is offline
Garage is empty, add now
Psyte is starting off with a positive reputation.
Butanol
i was researching alternative fuels and came across something called Butanol, apparently its a direct replacement for gasoline and can be made from corn. with these riseing gas prices its costing me a fortune to drive to work and back, i really hope this stuff catches on soon. http://www.butanol.com/ seems like a much cheaper and enviromentaly friendly alternative to ethanol blended gasoline, propane and natural gas.
  #2 (permalink)
Old 07-12-2006, 09:20 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Interesting write up, have to keep an eye on that...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 07-12-2006, 09:32 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
The website shows a fundamental lesson in organic chemistry. The more carbon atoms in the molecule, the more heat energy per gallon. Whats wrong with that? Greenhouse gas emissions (CO2), if you believe the "global warming is caused by man" argument.
Jim
  #4 (permalink)
Old 07-12-2006, 10:17 AM
PSKSAM2's Avatar
PSKSAM2 PSKSAM2 is offline
PSKSAM2 is gaining momentum as a positive member of FTE.PSKSAM2 is gaining momentum as a positive member of FTE.
Quote:
Jim
I was thinking the same thing when I read it. They claim is as "green" because it doesn't give off Nitrogen or Sulfur Oxides. It would be interesting to see a comparison of CO2 emmissions running on Gasoline, Ethanol, and Butanol. Perhaps the Butanol is less than Gasoline? If so, it could be a good intermediate solution for all the gasoline cars that are out there. Plus it would add to solving our dependence on oil.
It looks like DuPont and BP have taken notice of this fuel:
DuPont, BP join to make butanol; they say it outperforms ethanol as a fuel additive
-Jim
__________________
02 Mustang GT
98 B4000 SE 4 4x4 Auto
No single raindrop feels that it is responsible for the flood.
  #5 (permalink)
Old 07-12-2006, 01:42 PM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
Thing is, virtually all fuels with a notable exception of H2 contain some carbon, and so while CO2 emission is less than ideal, completely avoiding it is not easy.
  #6 (permalink)
Old 07-13-2006, 12:31 PM
Modern gasolines contain almost no sulfur, so where are the sulfur oxides going to come from? Nitrogen is in the air, so NOx is produced by high temperature combustion of any fuel. Butanol is no different than gasoline here either.
It performs better than ethanol as a fuel because it is chemically closer to gasoline in composition. That has advantages and disadvantages, depening upon its use. As an oxygenate additive to gasoline, it is less effective, because now you have one oxygen atom for four carbons instead of two.
I'm only playing devil's advocate here. There are no "magic bullets".
Jim
  #7 (permalink)
Old 07-13-2006, 05:50 PM
Diesels used to contain quite a bit of sulfur, but I'm not sure about recent ones -- I think they're a lot cleaner. Bunker or other heavy oils used mainly in furnaces or in ships can still contain some significant amount of sulfur.
The problem with ethanol is that engines made primarily for gasoline usually get miserable mpg on E85 because to run it efficiently, one would need a higher compression engine. On the other hand, butanol may be a lot closer to gasoline in many respects. What they had on the butanol website sounds almost too good to be true, but I didn't see any obvious red flag, or a BS alert, and their FAQ appeared to be honest, too.
  #8 (permalink)
Old 07-13-2006, 07:30 PM
the fact that it can be made from a renewable resource is what i think is important. gas prices are only going to keep going up as oil gets harder to find, butanol will probly either stay at a fixed price or go down as more and more companys start produceing it. last year i was only paying around 80 cents a liter for gas, this year its been as high as $1.24 (canada). thats quite a big jump in price for a year, i can only imagine how high its gona get in the next couple years.
  #9 (permalink)
Old 07-15-2006, 12:20 AM
There are quite a few fuels with a renewable source, so I don't think that's such a big deal. Being a possible direct replacement for gasoline with no adjustment to the engine is the main feature of butanol, IMHO. However, since it is not currently tested by 3rd parties or the fed, their claims about suitability are hard to verify.
Another thing, many of the sources that can be used to make ethanol or butanol can also be used as a human or livestock feed, and at some point, it might be more important to use them to feed people or animals. Of course there are quite a few waste products containing cellulose or other long chain carbohydrates that are not suitable even for a livestock feed, though making alcohol from them is usually somewhat more complicated.
  #10 (permalink)
Old 07-15-2006, 12:33 PM
fellro86's Avatar
1978 Ford F-150
Quote:
That part of the aargument is easy, it doesn't take away any of the food produced, rather, the fuels are a by product of processing the grains for food. Ethanol is not the only product of the distillation process, it only uses the starch. In the process of making corn sweetener, ethanol is produced anyway, it is just a matter of separating it out.I imagine butanol is the same. Livestock feed is also a byproduct of processing the grains for it's particular use.
__________________
  #11 (permalink)
Old 07-22-2006, 06:42 PM
Dino@his Dad's Dino@his Dad's is offline
Dino@his Dad's is gaining momentum as a positive member of FTE.
Butanol stinks !
Guys, butanol stinks ! That said, it looks like a very interesting fuel. But supposedly, if you get butanol 1 or 2, instead of straight chain butanol, thats when you get the noxious odors. Which version the Ramey process gives off I don't know, but butanol seems very much like a 'pour it in and go' option. DF, @ his Dad's house
  #12 (permalink)
Old 08-01-2006, 10:07 AM
PSKSAM2's Avatar
Here's Dupont/BP's official "biobutanol site".
biobutanol
They have a quote from Ford's CTO on there. It'll be interesting to see if Ford/GM puts out a statement such as "all models made since XXXX are ok to run on biobutanol" (assuming we begin to see biobutanol at gas stations). If they did, I'd imagine it could hurt their sales of E85 vehicles that they are really trying to push now. They may have to however, if Honda/Toyota/Nissan/etc come out with a similar statement. Either way, it is easy to ignore Ramey and EEI, but it will be harder to ignore a BP/Dupont partnership.
Dupont also quietly says during their flash animation that they are working on some "fast growing grasses" that could be used to produce biofuels in the future. Maybe we could plant some "victory lawns"...
-Jim
__________________
02 Mustang GT
  #13 (permalink)
Old 08-03-2006, 10:36 AM
Quote:
Are those vehicles only flex fuel capable, or optimized for E85? I think it's the former, and they push them because they get 1.2 mpg credit for flex fuel capable vehicles.
I think they came out with E85 because they had no other option at that time, and because the manufacture of alcohol is a well known process and can use the plentiful US corn.
However, a fuel that could be a direct replacement for gasoline even in older vehicles, would be a lot more desirable. Even though early adopters such as Brasil are heavily invested in ethanol, my bet is that ethanol could fade away in the US and replaced by something else that is more compatible with gasoline. Heavier alcohols such as butanol, propanol (a sibling of rubbing alcohol) or pentanol are possible candidates, as long as they can be made cheaply by fermenting. We already know that's the case for butanol.
  #14 (permalink)
Old 08-03-2006, 11:45 AM
furball69's Avatar
furball69 furball69 is offline
furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.
Getting away from CO2 emissions
Like the idea of Hydrogen fuel cells being the untimate fuel source because there are no emissions except for water, forget or close their eyes to the fact that the huge amounts of electricity needed to produce hydrogen is produced primarily by burning coal. Not to mention that the plants that are grown to make biofuels don't grow in clay alone, they have to be fertilized and fertilizer comes from natural gas.
Quote:
The Harkin/Roberts letter notes that natural gas now accounts for 90 percent of the cost of nitrogen fertilizer production. In addition, rising U.S. natural gas prices have caused U.S. nitrogen fertilizer production costs to jump from about $80 a ton during the 1990's to over $300 a ton last year, despite substantial improvements in efficiency by the domestic nitrogen fertilizer industry. The result is that 30 percent of the nitrogen fertilizer production in this country has moved overseas, with much more at risk of moving overseas in the near future.
from http://harkin.senate.gov/press/print-release.cfm?id=236144
I know for a fact that producing ethanol converts the available sugars into CO2 and Ethanol, at about equal rates, by weight. So a ton of sugar converts to roughly, a half ton of alcohol and a half ton of CO2.
By the sounds of this butanol, it has double the carbon as ethanol so maybe the CO2 emissions from the fermentation process isn't as high as producing Ethanol but that carbon is going to be realeased somewhere in the combustion process.
Believing that we can get away from fossil fuel use overnight is a pipe dream. Maybe it will happen one day, when someone invents a way to store the sun's energy directly into a storage device, that can be used immediately without any post-processing. Oh wait, we already have those. Hopefully the (environmental) cost of making solar panels, batteries and electric motors is lower than that of an equivalent measure of electricity, produced by conventional means would be, or even an efficient CNG or hybrid vehicle.
To add, the most logical thing to do is build vehicles that run on CNG. That way, instead of going through several conversion and transportation stages of natural gas into fertilizer, into plants, into ethanol/butanol/vegetable oil ->biodiesel... why not just take it out of the ground and put it in the car. It costs money, and time, and even more fuel energy to go through all these conversion and transportation stages, it doesn't make much sense.
__________________
"It's not the votes that count, it's who counts the votes"
I can't outrun bullets, but I might outrun an *alien* with an empty gun.
My fuel economy calculators
  #15 (permalink)
Old 08-03-2006, 11:52 AM
PSKSAM2's Avatar
You're right, hadn't thought ot the CAFE credit. It tough to give a credit for butanol, though, since it seems that it can be run in an unmodified vehicle. I don't think anyone wants to see car companies get a credit for doing absolutely nothing to improve mileage, alternative fuel adoption, or emissions. I'm wondering if there is any incentive that would move car companies to say "butanol doesn't void the warranty" (similar to what they've said for biodiesel for newer diesels, or E85 for FFV's).
In this report it was even noted, "The auto manufacturers stated that the CAFE incentive program has been a major factor in developing and manufacturing alternative fuel vehicles in high volumes".
NHTSA - REPORT TO CONGRESS Effects of the Alternative Motor Fuels Act, CAFE Incentives Policy, Summary of Findings and Recommendations
It is interesting that one of the recommedations was to link the CAFE credit to the amount of alternative fuel that is used. Sure, it's great that the car companies produced and sold the FFV cars, but is anyone using the alternative fuel? Very similar issue with butanol since it is a claimed direct replacement for gasoline. Maybe there should be a CAFE like program on the oil companies to sell a certain amount of alternative fuels? Just a thought, I'm not in favor of more laws generally, and of course it'd probably get quashed by a lobby.
I absolutely agree, and felt that needed to be quoted.
-Jim
__________________
02 Mustang GT
Tags
1997, 1998, 42, biobutinol, butanol, cars, f150, ford, gas, nox, older, propano, stinks, truck, v6, void, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
