Header Installation
Header Installation
Take a torch and heat head until cherry red around bolt, while having a pair of vicegrips on the head of the bolt. when heated remove vicegrips and apply wrench and slowly rock back and forth until it will move freely. take it nice and slow. also be careful. If you know that the old exhast manifold is toast you can you can take a big chishel and carefully tab on each section and it will break up really easy, but of course undo the four bottom bolts first. this will let you better access to the bolts. Also if anything left sticking out of the old broken one. heat up and take out with vicegrips
Tibbetsni
03-13-2011 12:09 AM
bghnkinf250
03-23-2010 03:38 PM
95badbird
04-28-2005 04:50 PM
