Compression Test
Compression Test
What is involved in testing the comression on a NA 7.3L by using the glow plug holes. What equipment do I need? Ive seen compression testers at Autozone but I dont think they have the right adapters or go up high enough.
The truck has 230,000 miles, new injectors, newer ip, return lines, glowplugs and relay, and still starts like ****. I just thought if it had bad compression it would burn alot of oil but its only a quart low every 3000 miles and thats mostly from normal leaks around the oil cooler and front main.
on
1 Post
Dieseldan,
Have you done the batteries, starter cables and starter?
Depending on how much starting you do, starters start to get tired around 150k to 200k. As the starter looses its pull the engine will become more and more difficult to start. Note, a tired starter may not be all that noticable just from listening to it turn.
Old batteries won't deliver the amps needed.
Old cables or bad connections also tend to reduce the amps.
Just a thought....
Seb...
Just a thought....
Seb...
dieselaholic
07-13-2011 12:52 AM
cowboy.2010
02-12-2009 10:10 AM
powerfarmer
16
06-22-2008 11:56 PM
