2001 ford escape battery replacement - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 07-10-2006, 06:45 PM
dawson2381 dawson2381 is offline
dawson2381 is starting off with a positive reputation.
Hey guys I have a dumb question but if someone could help me I would appreciate the advice. I am about to change the battery in my ford escape it had a 590cca in it I live in canada where it gets really cold and I found a battery the exact same size and everything only its a little bigger its a 650cca would doing this hurt anything like the vehicle or warranty or anything let me know thanks.
Old 07-10-2006, 06:54 PM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
HI Dawson... We may wanna move you over to the Escape forum...
But the question seems easy enough.. the 650cca should'nt be a problem.
Old 07-10-2006, 08:29 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Thread moved to Escape forum.
That battery size should be ok as long as it fits in the tray. Those few extra cranking amps will help with our cold Canadian winters.
-Matt
Old 07-14-2006, 10:55 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
put the highest CCA battery that will fit, I am running a 1000CCA
'86 F150 302- Which Battery? D Harry 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 03-06-2017 09:31 AM
Pretend dead battery privateer, eh 1973 - 1979 F-100 & Larger F-Series Trucks 11 01-24-2014 07:12 AM
Marine batteries? PSD2005 6.0L Power Stroke Diesel 8 05-25-2012 09:06 PM
Motorcraft 650cca,750cca,850cca??? Supercab 1999 - 2003 7.3L Power Stroke Diesel 15 08-05-2010 03:12 PM
how many cca's are TOO many? oreocreaming Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 07-04-2010 01:18 PM
Tags
2001, 2006, 2008, amps, battery, change, cold, cranking, escape, ford, replace, replacement, required, size, tools
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
