Lost key - replace ignition switch? - Ford Truck Enthusiasts Forums
Old 07-10-2006, 02:26 PM
JimJames99 JimJames99 is offline
JimJames99 is starting off with a positive reputation.
I lent my friend my 1970 F100 and he promptly lost the keys (ignition and gas cap). Any advice if it's easier/cheaper to have a locksmith rekey both or if I should just replace with a new/replacement ignition switch?
Also any ideas of getting the locking gas cap off in order to replace it?!?
Many thanks, Jim.
Old 07-10-2006, 02:34 PM
Spudzville Spudzville is offline
Spudzville is starting off with a positive reputation.
Since I don't know where you live, and prices vary *so much* I can't say whether it's cheaper to replace ignition & gas cap...however...a locksmith can make keys for both of these by using what is called the "impression" method -or- they can pick open the gas cap for you to replace it -and- pick the ignition lock to turn it to Acc. position for removal & produce an 'original' key (which will also work the door locks...)
If I were you, I'd call a lock shop (or two) for pricing and options here.
Old 07-10-2006, 02:38 PM
Many thanks Spudz! I will do that right now. Jim.
Old 07-10-2006, 02:44 PM
You're welcome, Jim. I own a '70 F100 also...
Old 07-10-2006, 02:49 PM
fordtruckn's Avatar
fordtruckn fordtruckn is offline
fordtruckn is starting off with a positive reputation.
Don't forget your door locks. If you replace your ignition, you still won't be able to lock/unlock your doors.
Old 07-10-2006, 03:00 PM
Assuming the lost ignition key also worked the door locks...it would be easy enough for a locksmith to "read" the existing ignition lock & re-make the original key. *Probably* about the same price as a new ignition lock to perform this service, but locksmith prices vary so much...I used to be in that industry.
I have (when making keys) cut the ignition pattern on one side, door pattern on the other; cut different (old ford) vehicle patterns on opposite sides...too funny. Wish things could still be that easy *sigh*.
Best to all.
Old 07-10-2006, 03:02 PM
fordtruckn's Avatar
I used to have one of those keys - Two fords and one key. Worked out great.
Old 07-10-2006, 04:51 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Don't you have to have the key in the ignition to be able to remove the lock to replace it??
I think rekeying is the only answer.
John
Old 07-10-2006, 05:00 PM
Thanks all! Much appreciated. Locksmith is on his way. Jim.
Old 07-10-2006, 07:26 PM
Jowilker, the answer to this one is: "not necessarily"--on our old trucks, the ignition needs to be in the Acc position to enable the retainer to be depressed...which is then accomplished by pushing a thin wire into that teeny poke-hole next to the keyway. Most newer cars' retainers are 'enabled' by the key being in the keyway (which can sometimes be 'faked' by holding a pick there instead--after picking, rotating the lock to the needed position) and then pressing in the retainer from outside the lock....usually buried deep inside the steering column....ugh)
They didn't pay me enough to keep up with the tooling & info updates....but I'm glad to assist if I can.
Old 07-10-2006, 07:31 PM
Oh, man, I've been out of it for so long...(slaps forehead!) The whole lock assembly can come out of the dash easily enough...description above tells how to remove plug (keyway) for rekeying...
Sorry folks, I'm still quite new to cyber-repair!
Old 07-11-2006, 07:03 AM
jowilker's Avatar
Uh Ok, but how do you get it to the acc position without the key??
I think you have to get the (plug) as you call it out first to be able to remove the complete switch, no??
John
Old 07-11-2006, 11:10 AM
No, well, not on my rig anyhow...(70 F100)...the whole assy in held to the dash by a spanner-type retainer. 3 notches in the bezel surrounding keyway, use spanner tool to unscrew this, pull ignition out from behind dash, disconnect the harness. Plug removal not necessary to remove lock assy. Sorry, I didn't think this completely thru earlier, will think it out before opening my mouth next time. For plug removal: most convenient if one has a key....otherwise, must pick the lock to rotate it to acc position. For this unit, key doesn't need to be in the keyway for plug removal.
Actually, I had hoped Jim's locksmith would have told him to remove ignition, or perhaps a door lock if the key worked them too--bring it to the shop (maybe even helped with the how-to...we did stuff like that for our customers) and save the service call fee. Of course, maybe that's why it didn't pay so great...?
Darn, just when I thought I was being helpful--I'll try harder in the future.
Old 07-11-2006, 01:59 PM
Just got home. The locksmith simply made an impression and filed a new key by hand. Same thing for the gas cap. Probably 20 minutes work in total. $85 which I was happy to pay since I didn't need to rekey the door locks as well.
Thanks all !! Jim.
Old 07-15-2006, 01:50 PM
DarkWolf40's Avatar
DarkWolf40 DarkWolf40 is offline
DarkWolf40 is starting off with a positive reputation.
I'd be billing the idiot who lost the key in the first place. Also, he'd never get to borrow one of my rigs again.
no key for locking gas cap moconnor603 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 11-26-2016 09:25 AM
1979 Lost Key Replacement Optons threepiece 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-26-2016 08:03 PM
1995 F150 351w truck won't shut off?? Genadekw 1987 - 1996 F150 & Larger F-Series Trucks 1 05-12-2016 02:57 PM
Ignition Removal Without Key? Obtuse1 1961 - 1966 F-100 & Larger F-Series Trucks 17 01-25-2014 12:29 PM
I Lost Keys jjaj46 1987 - 1996 F150 & Larger F-Series Trucks 36 06-11-2007 09:03 AM
Tags
2000, f150, ford, hole, ignition, key, keys, lost, poke, rekeying, removal, replace, replacing, rig, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
