How much would it cost to Rebuild Front end - Ford Truck Enthusiasts Forums
Old 07-10-2006, 01:20 PM
d_stange d_stange is offline
d_stange is starting off with a positive reputation.
Have a 1990 F250 4x4 5.8l ZF5. I think my front end is going to need some work. How much does it cost in a worst case scenario to go through the front end on these trucks. I need an alignment because it pulls bad to the right and that tire is showing a lot of wear and i'm afraid being it is a plow truck that it going to need some part. Also, i noticed i have a little grease coming out of my manual locking hubs. I think there ford hubs because the have the red center. Is going to be around a grand with labor to get this thing fixed up good or am i better off junking it out. Also the transfer case has a little leak, not bad but something i should also have fixed i don't like a leaky transfer case.
Old 07-10-2006, 06:51 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
It depends on what's wrong with it. I went through rockauto.com once and priced out every wear item in the front end - rotors, calipers, pads, bearings, seals, ball joints, tie rod ends, steering box, i beam bushings, radius arm bushings, and whatever else I'm forgetting - and it was about a grand just for parts. And that was a 2wd F-150.
Now, chances are that not everything needs to be replaced. It probably just needs an alignment. TTB trucks are notorious for drifting out of alignment. If it pulls when you hit the brakes, replace the calipers. If it pulls all the time, it's probably just alignment.
You also didn't say how many miles - if you're looking at a 300k plow truck, then a lot is probably wrong with it.
Old 07-10-2006, 09:28 PM
Josh88Ford Josh88Ford is offline
Josh88Ford is gaining momentum as a positive member of FTE.
i had mine rebuilt basically.
axle u-joint 27.81 55.62
wheel seal 11.31 22.62
alignmet bushings 26.97 53.94
replace front axle u joints
retourqe upper and lower ball joints 209.40
(i had a back yard mechanic do my ball joints...i could have done his work with my eyes closed better)
install alignmet bushings 69.95
alignment 66.95
500 bucks, got a fairly good deal
i would get new lockouts. Warn or Milemarker. I had my stock ones "rebuilt" because the guy hit on mine with a hammer to get them out. They ended up breaking not too long after. 60-70 for the lockouts, and $30 installed unless you have the tools. I would have needed a few special tools so i just had them installed professionally..
Old 07-12-2006, 06:59 AM
How hard is it to do a solid axle swap on these trucks. With the plow on there it would hold up better. what do i need for parts and so on and what needs to be changed for a solid front axle to bolt up.
Old 07-12-2006, 11:29 AM
andym's Avatar
All you need is a solid Dana 60 from an F-350 from 1986.5 to 1997. It will bolt right up, everything else is the same.
Be prepared to shell out about $1k for the axle, though. They are in high demand.
Old 07-12-2006, 01:56 PM
Dang, that's a chunk of change!! guess i won't be doing that anytime soon.
Old 07-12-2006, 03:32 PM
you can go with a dana 44 from the 70's fords. Usually you will pay a few bucks for those or have to do some work to them. Go to a local junk yard and see wht they got. They might take one off a truck with no title..
B&R in Mapleton, mn on hwy 22 is prolly the biggest salvage yard in MN
Old 07-14-2006, 05:31 AM
harjp1959 harjp1959 is offline
harjp1959 is starting off with a positive reputation.
My '95 F250 4x4 5.8L was pulling bad to the right when I got it. Since I'm near a lot of desert offroad areas, I took it to a 4x4 shop to see what I should do to make the truck fully offroad worthy.
The owner immediately noticed that the front springs were shot. The front end was lower than the rear, and the whole truck drooped to one side. He rebuilt the springs (and installed Rancho 5000s). The front end now sits slightly higher than the rear, side to side it's level, and the truck drives straight as an arrow.
IWE (4WD) Vacuum Test & Results Ranger Bob 2004 - 2008 F150 12 01-31-2014 05:35 AM
Transfer case / Hubs / Diff / Vacuum confusion Enduroman 6.0L Power Stroke Diesel 17 12-06-2013 02:53 PM
Transfer case woes jimjoebob99 Clutch, Transmission, Differential, Axle & Transfer Case 2 12-01-2009 06:46 AM
Auto Hubs on 4x4, replacement? Powerstrokedlariat 1999 - 2003 7.3L Power Stroke Diesel 6 12-30-2004 06:32 AM
Front axle seals on 01 F-250 4x4 SMB Offroad & 4x4 8 05-18-2003 11:37 AM
Tags
cost, end, f250, front, rebuild, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
