Cured my wandering steering
I have an `05 V10 4x4 Limited that we bought with 16k miles on it and really began to be annoyed by the steering within a week of getting it. My first step was to install the Hellwig rear sway bar, and though it made a very noticeable difference to both my wife and I, it wasn't a cure.
I'd been putting off adjusting the steering box until yesterday, and that finally did the trick. Thanks to the instructions I found on this board I spent about 45 minutes adjusting and test driving to make sure I hadn't tightened too much, and after about a turn and a half of the allen screw, the steering is nice and taught with no slop in the wheel. Previously I could jiggle the wheel nearly an inch either way while driving down the highway and not affect the vehicle's path. Now the steering feels directly connected and responsive!
I towed our travel trailer back from storage right after the adjustment, and wow, like no more white knuckles!
BTW, even though I'm 6'2" I had to stand on a step ladder to be able to reach down in from the top to get to the steering box. This Ex is one big truck!
Actually, the longwinded instructions involved taking the steering wheel off and measuring torque on the steering shaft. Much more involved than I wanted to mess with. Basically all you need to do is locate the allen head bolt and locknut on top of the steering box (close to the radiator). I believe the locknut was a 5/8" on my box. Mark the allen bolt so you can tell the orientation that you started from and then loosen the locknut. Turn the allen bolt clockwise a quarter turn to tighten the gear mesh. Tighten the locknut back up and take her for a spin. Be careful, because if you overtighten the steering may be so tight as to get extremely stiff on a tight turn, causing you to veer off course. Repeat the tighten and test drive until you're satisfied with the performance. If you overtighten, turn back the allen bolt a quarter turn counter clockwise.
There is a risk of over tightening the box and causing it to wear out prematurely, so I tightened it to the point where the slop was gone, and no further.
It's so simple, I'm embarassed I didn't try it sooner.
KellySue, the "proper" instructions are here: http://www.rv.net/forum/index.cfm/fu...7.cfm#17057497
Doug
Doug
The following users liked this post:
I ended up with a total of between 5 and 6 quarter turns. It wasn't an incredibly precise process for me, because I couldn't hold the allen head screw in position while tightening the locknut. Maybe if I were 7' tall it would have been easier. I just didn't have the reach to use both hands at a time. It took at least a 1/2 turn before I started to feel a noticeable improvement. Maybe adjusting it from underneath the truck would have been easier, but I wanted to see the allen screw turning, and not be guessing.
To find the steering box, follow the steering shaft out of the firewall toward the radiator. The shaft terminates into the box down low and in front of the front axle (on my 4x4 anyway). The Allen screw and locknut are right on top the box. Depending on lighting, a flashlight might help to see it.
Whatever you do, when you're done adjusting make sure you get that locknut tight. I gave mine a second tightening last night.
I just want to say thank you very much for posting the Thread. I did the adjustment on my excursion last weekend and wow what a difference it made. I towed the trailer the other day and it made a huge difference in the wandering of the Truck!!! I think I turned the adjustment screw about 4 to 5 times and all the slop in steering is gone!!!.. Thanks!!!!
I'm wondering about other's mileage as well when needing this done. I can understand KellySue's needing the adjustment with 140K miles, but dbtx with 15k seems like a factory spec that must not have been met, too early for wear isn't it? If so, will Ford do this under warranty or will they just tell me it's OK or worse yet screw it up? Anyone tried to have Ford make this adjustment via warranty coverage?
I have a 2005 6.0psd - assuming the steering box is the same I'm gonna check and possibly adjust mine since I have some vagueness/wandering but not as bad as some here seem to describe (kind of a subjective thing). I have the factory sway bar and plan to add Roadmaster Active Suspension in the back when I get a travel trailer this Fall, but oddly the wandering seems worse on mine unloaded then when I tow our boat (only 4k lbs or so). The weight on the back end seems to stabilze things on the hiway.
