Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-10-2006, 10:35 AM
dbtx dbtx is offline
dbtx is starting off with a positive reputation.
Talking Cured my wandering steering
I have an `05 V10 4x4 Limited that we bought with 16k miles on it and really began to be annoyed by the steering within a week of getting it. My first step was to install the Hellwig rear sway bar, and though it made a very noticeable difference to both my wife and I, it wasn't a cure.
I'd been putting off adjusting the steering box until yesterday, and that finally did the trick. Thanks to the instructions I found on this board I spent about 45 minutes adjusting and test driving to make sure I hadn't tightened too much, and after about a turn and a half of the allen screw, the steering is nice and taught with no slop in the wheel. Previously I could jiggle the wheel nearly an inch either way while driving down the highway and not affect the vehicle's path. Now the steering feels directly connected and responsive!
I towed our travel trailer back from storage right after the adjustment, and wow, like no more white knuckles!
BTW, even though I'm 6'2" I had to stand on a step ladder to be able to reach down in from the top to get to the steering box. This Ex is one big truck!
__________________
2008 Expedition EL 4x2 with heavy duty tow package
2007 F150 XLT SCrew 4.6L Black with Chrome package
Mods: Katzkin Dark Charcoal Leather Interior, Rubber Bed Mat
2005 Excursion 4x4 Limited V10 (traded on the Expy)
Mods: Helwig Rear Sway Bar
  #2 (permalink)
Old 07-10-2006, 12:13 PM
SSGG SSGG is offline
SSGG is starting off with a positive reputation.
Could you throw up the link to the instructions page? I am glad to hear that you got the steering tighter, I need to, too.
Wes
__________________
SuperSizedGroceryGetter - '01 Ex. Limited 4x4 PSD - AFE stage 2, Bank's SS 4" pwr. el back, AIH del./boost port, CCV KOpot, SPA Duals(boost/egt,fuel/tranny), trucool-max,203 tstat.,Hutch mod,ATS...
  #3 (permalink)
Old 07-10-2006, 12:22 PM
KellySue KellySue is offline
KellySue is starting off with a positive reputation.
I would interested in the link. I have a 01 w/139,000 miles and have slack in steering box. I have adjusted it some but would like the specs so I don't go too far.
  #4 (permalink)
Old 07-10-2006, 12:33 PM
Actually, the longwinded instructions involved taking the steering wheel off and measuring torque on the steering shaft. Much more involved than I wanted to mess with. Basically all you need to do is locate the allen head bolt and locknut on top of the steering box (close to the radiator). I believe the locknut was a 5/8" on my box. Mark the allen bolt so you can tell the orientation that you started from and then loosen the locknut. Turn the allen bolt clockwise a quarter turn to tighten the gear mesh. Tighten the locknut back up and take her for a spin. Be careful, because if you overtighten the steering may be so tight as to get extremely stiff on a tight turn, causing you to veer off course. Repeat the tighten and test drive until you're satisfied with the performance. If you overtighten, turn back the allen bolt a quarter turn counter clockwise.
There is a risk of over tightening the box and causing it to wear out prematurely, so I tightened it to the point where the slop was gone, and no further.
It's so simple, I'm embarassed I didn't try it sooner.
KellySue, the "proper" instructions are here: http://www.rv.net/forum/index.cfm/fu...7.cfm#17057497
Doug
__________________
  #5 (permalink)
Old 07-10-2006, 12:37 PM
Thanks for the info. I have adjusted some already and was concerned about going too far but my box may be worn to much anyway. It drives very well with exception of the slack in the box.
  #6 (permalink)
Old 07-10-2006, 12:46 PM
'preciate the link. Where in Tx are ya?
Wes
__________________
  #7 (permalink)
Old 07-10-2006, 03:06 PM
Allen, Tx. Which is just north of Plano. Almost Oklahoma.
and you?
__________________
  #8 (permalink)
Old 07-10-2006, 05:30 PM
Bridge City, 100 miles SE of Houston +/-. Almost Louisiana, but not. I have some inlaws N of Dallas and my Dad used to work in Perryton and my brother in Texarkana,so ,its been a while but i have been up your way.
Wes
__________________
  #9 (permalink)
Old 07-10-2006, 05:47 PM
post-man post-man is offline
post-man is starting off with a positive reputation.
dbtx, did you replace the stock sway bar on your '05 with the Hellwig sway bar?
__________________
04 X Limited, 6.0 PSD 4x4,
Banks 4" turbo-back Monster Exhaust
Oil Guard EPS-20-PSD Bypass Filter kit
Bilstein Shocks
Powerslot rotors w/Hawk LTS pads
EGR disconnected
ZooDad Intake Mod,
3 Gauge Autometer Sport Comp A-Pillar
BriteBox
Ford Remote Start
SCT Xcalibrator 2 (LIPD Tunes)
  #10 (permalink)
Old 07-10-2006, 06:37 PM
post-man - No oem sway bar came on the truck. The rear sway came with the 05 "tow package" which evidently my truck didn't have.
__________________
  #11 (permalink)
Old 07-10-2006, 10:44 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
Never fry bacon NAKED!
2002 Ford F-250
My Garage
Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold
Doug, I know different vehicle will vary, but I'm curious, how many times did you do the quarter turn before you were happy?
Also, where the heck is the steering box located at on the Ex, and where on the box is the allen head bolt?
Stewart
__________________
The Brotherhood of FTE <~click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody
2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
  #12 (permalink)
Old 07-11-2006, 08:33 AM
I ended up with a total of between 5 and 6 quarter turns. It wasn't an incredibly precise process for me, because I couldn't hold the allen head screw in position while tightening the locknut. Maybe if I were 7' tall it would have been easier. I just didn't have the reach to use both hands at a time. It took at least a 1/2 turn before I started to feel a noticeable improvement. Maybe adjusting it from underneath the truck would have been easier, but I wanted to see the allen screw turning, and not be guessing.
To find the steering box, follow the steering shaft out of the firewall toward the radiator. The shaft terminates into the box down low and in front of the front axle (on my 4x4 anyway). The Allen screw and locknut are right on top the box. Depending on lighting, a flashlight might help to see it.
Whatever you do, when you're done adjusting make sure you get that locknut tight. I gave mine a second tightening last night.
__________________
  #13 (permalink)
Old 07-17-2006, 09:33 PM
PSD05_Heckert PSD05_Heckert is offline
PSD05_Heckert is starting off with a positive reputation.
I just want to say thank you very much for posting the Thread. I did the adjustment on my excursion last weekend and wow what a difference it made. I towed the trailer the other day and it made a huge difference in the wandering of the Truck!!! I think I turned the adjustment screw about 4 to 5 times and all the slop in steering is gone!!!.. Thanks!!!!
  #14 (permalink)
Old 07-18-2006, 12:02 PM
Heckert,
How many miles is on your X? Your turned it 5/6 times ? I was afraid to turn it that many times.
  #15 (permalink)
Old 07-18-2006, 02:15 PM
2005X 2005X is offline
2005X is starting off with a positive reputation.
I'm wondering about other's mileage as well when needing this done. I can understand KellySue's needing the adjustment with 140K miles, but dbtx with 15k seems like a factory spec that must not have been met, too early for wear isn't it? If so, will Ford do this under warranty or will they just tell me it's OK or worse yet screw it up? Anyone tried to have Ford make this adjustment via warranty coverage?
I have a 2005 6.0psd - assuming the steering box is the same I'm gonna check and possibly adjust mine since I have some vagueness/wandering but not as bad as some here seem to describe (kind of a subjective thing). I have the factory sway bar and plan to add Roadmaster Active Suspension in the back when I get a travel trailer this Fall, but oddly the wandering seems worse on mine unloaded then when I tow our boat (only 4k lbs or so). The weight on the back end seems to stabilze things on the hiway.
__________________
2005 6.0psd Excursion 4x4 black/tan EB w/ rear chairs.
I missed our old Suburban for 10 minutes...
Tags
2002 , box , duty , excursion , f250 , ford , heavy , play , stays , steering , truck , turn , turned , wander , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
