Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #91 (permalink)
Old 10-07-2009, 12:19 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
Never fry bacon NAKED!
2002 Ford F-250
My Garage
Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold
Quote:
Originally Posted by Dakrri View Post
I'm wondering if after other FTE tighten their steering box up, if they too lost the spring back when in a curve.
I would say you overtightened it then.
Quote:
I think I still need to tighen mine more. It sloppy to me at highway speed, but my wife says there is to much response in the steering.
It's just a guess, but I'd say you have more going on than the steering box needing to be adjusted.
What all have you done to your steering and suspension?
Check out the links in this thread. http://www.ford-trucks.com/forums/789595-attn-dup-steering-wander-search-results-for-you.html See if the info contained within can help you. Steering wander on these beasts isn't limited to adjusting the steering box.
Stewart
__________________
The Brotherhood of FTE <~click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody
2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
  #92 (permalink)
Old 10-07-2009, 12:31 PM
Dakrri's Avatar
Dakrri Dakrri is offline
Dakrri is starting off with a positive reputation.
We have new ball joints, sway bar bushings and end links, shocks, nitrogen filled tires.
When the X is parked in the driveway, I have play in the steering, both left and right, when I turn the wheel back and forth.
I’d say play is from 12:00 to 10:00 when turning the wheel left, and 12:00 to 2:00 when turning right….standing still.
At highway speed it seems to wander, but can be corrected safely.
Weird
Thanks
dakrri
  #93 (permalink)
Old 10-07-2009, 12:57 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
Keep tightening the box until it is inefective. You didn't mention steering damper.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #94 (permalink)
Old 10-07-2009, 01:12 PM
Dakrri's Avatar
I hoping someone can take theirs for a ride and see what type of feedback/spring back they get when turning….does it actrully spring back like a car? And how much “play” they have while standing still.
I’ll tinker with mine this Saturday. It’s a “Btch” to get at my steering box. In order to get at it without anything in the way, I have to remove one battery, the air filter, the air filter/battery bracket, the metal pipe for the turbo intake.
I did not replace the steering damper yet.
Thanks
dakrri
  #95 (permalink)
Old 10-07-2009, 03:15 PM
howler4x4's Avatar
howler4x4 howler4x4 is offline
howler4x4 is starting off with a positive reputation.
Not sure it's not mentioned somewhere above, but rusted axle ujoints can actually have enough resistance to limit the self-centering action that's built into the steering geometry.
And yes, the Ex steering should return to center when turning ('feedback/spring back' right?)
__________________
2001 Excursion Limited V-10 4x4
'48 Willys / '77 Scout Hybrid http://liorclub.org/Members/bob.htm
Proud Member of Team 53449 - FTE's for Cancer Research http://www.ford-trucks.com/forums/56...ding-home.html
  #96 (permalink)
Old 10-07-2009, 03:28 PM
Dakrri's Avatar
feedback/spring back' right...yes return to center is what I meant. But if it has too much play or wander, will it return to center? I guess I need to try and turn it both ways and do some test driving.
thanks
  #97 (permalink)
Old 10-07-2009, 04:51 PM
Stewart_H's Avatar
2002 Ford F-250
My Garage
You don't have your sig filled out yet, what are the specs on your Ex? Year, 2-wheel, 4-wheel, PSD or gasser, etc.
Do you still have the OEM springs?
Stewart
__________________
  #98 (permalink)
Old 10-07-2009, 08:02 PM
Dakrri's Avatar
I have a 2004 4x4 Diesel limited...it won't let me update my signature, it says I'm missing a "token"??
I'll try some adjustments on Saturday.
__________________
2004 EXCURSION LIMITED 6.0 DIESEL 4X4
  #99 (permalink)
Old 10-07-2009, 08:34 PM
Stewart_H's Avatar
2002 Ford F-250
My Garage
Do you still have the OEM springs? What kind of tires do you have? What load rating?
Stewart
__________________
  #100 (permalink)
Old 10-07-2009, 09:18 PM
EXv10's Avatar
It still should spring back. My '00 has 0 play at 145k miles.
__________________
  #101 (permalink)
Old 10-07-2009, 11:43 PM
blackford4x4 blackford4x4 is offline
blackford4x4 is starting off with a positive reputation.
steering wander
steering box replacement fixed mine the (steering slack) ... was still under warranty
  #102 (permalink)
Old 10-08-2009, 09:46 AM
Dakrri's Avatar
I drove my EX 30-miles to work today and I think I have the steering box set too tight. The steering feels “heavy” and the steering wheel does not go back to center when I turn.
If I was in a large space/parking lot, and turned the wheels all the way right or left I could keep going around in circles with my hands off the steering wheel.
dakrri
__________________
  #103 (permalink)
Old 10-08-2009, 11:49 AM
EXv10's Avatar
Jack both wheels up, turn lock to lock, check for binding.
__________________
  #104 (permalink)
Old 10-08-2009, 06:27 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy X_Hemi_Guy is offline
X_Hemi_Guy has a great reputation on FTE. X_Hemi_Guy has a great reputation on FTE. X_Hemi_Guy has a great reputation on FTE. X_Hemi_Guy has a great reputation on FTE. X_Hemi_Guy has a great reputation on FTE.
Overtightening is a very real possibility since there is no real criteria given for how much to tighten...many have other possible issues going on when they attack the steering box and end up with an overtightened mesh on the steering...
I'd back off on the steering mesh gears to see if that fixes it...having a steering wheel that stays 'locked' in a turn is dangerous and should be adressed quickly IMO.
good luck,
Joe.
__________________
2005 Ex V10 4.30's
Hensley Arrow / Rear Hellwig / Prodigy Brake Controller / RAS / Bilsteins / K&N drop in / SCT X3 Tuner with 5-Star Tunes / Aeroforce Tech OBDII Digital Gauge / Hawk LTS Pads
2007 JayFlight 31BHDS (2 slides 3 women just right! )
3rd Annual Excursion Diversion / Ford Rally 2010 here: http://www.ford-trucks.com/forums/88...ml#post7941270
  #105 (permalink)
Old 10-10-2009, 01:52 PM
Dakrri's Avatar
Ok, I spent the morning adjusting the steering box. I turned it all the way out, teat drove it and then turned it all the in, back it off a 1/4 turn, and test drove it.
There was not really any noticeable difference. I have a 106,000 miles on my 2004 6.0 EX and I think it may be time to replace the steering box. The steering is somewhat “tight” and it is comfortable at highway speeds so I’ll wait until it worsens.
Any idea on the cost of a new box?
Thanks for all the input....
Hey....it’s just stared snowing here in Sheboygan WI.....Ugh!!
Go Badgers!!
__________________
Tags
2002 , box , duty , excursion , f250 , ford , heavy , play , stays , steering , truck , turn , turned , wander , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
