Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #76 (permalink)
Old 05-25-2009, 12:11 PM
mannasteve mannasteve is offline
mannasteve is starting off with a positive reputation.
here is a picture. 3/4 turn for me. Big difference.
  #77 (permalink)
Old 05-25-2009, 01:17 PM
superfuzz87 superfuzz87 is offline
superfuzz87 is starting off with a positive reputation.
Quote:
__________________
2002 Ex Limited Ultimate, Volant CAI, FPR shim, Hypertech Power Programmer, U-codes, RAS, Bilsteins, MBRP...waiting for install; DFA CCK, rear tapered blocks (maybe)
  #78 (permalink)
Old 06-25-2009, 12:35 PM
EddieEX10 EddieEX10 is offline
EddieEX10 is starting off with a positive reputation.
Performed this adjustment last weekend. Makes the truck drive like new. Sure appreciate you all sharing the instructions and results. I turned mine 1.5 turns and it could probably use another half turn. BTW, it's an 04 with 89,000.
A small amount of steering fluid was released when I loosed the 5/8" nut. Not a major deal though. It doesn't appear to be leaking after I retightened it.
  #79 (permalink)
Old 06-26-2009, 12:52 AM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
No, it won't leak. ........It is strange how my steering wheel has zero play in it with 140k miles on it.
  #80 (permalink)
Old 06-30-2009, 02:12 PM
04X 04X is offline
04X is starting off with a positive reputation.
I had been noticing it more difficult to drive my '04 4x4 Excursion lately. It seemed to not take minor steering input and then when it finally would it would be like it all caught up at once. I put it up on the jack last night and found my driver's side hub locked, but my passenger side was free. I'm not sure how the systems 'play' together, but I freed it up and it seemed to make a big difference driving in to work this morning.
I'm going to try the steering box adjustment (most likely) this weekend and maybe run a little more air pressure in the tires.
  #81 (permalink)
Old 06-30-2009, 02:17 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy X_Hemi_Guy is offline
X_Hemi_Guy has a great reputation on FTE. X_Hemi_Guy has a great reputation on FTE. X_Hemi_Guy has a great reputation on FTE. X_Hemi_Guy has a great reputation on FTE. X_Hemi_Guy has a great reputation on FTE.
Make sure you take a look at this site for Hub Maintenance...great site!
http://www.guzzle7pt3.com/allube.php
and here is his main page
http://www.guzzle7pt3.com/maint.php
Joe.
__________________
2005 Ex V10 4.30's
Hensley Arrow / Rear Hellwig / Prodigy brake controller / RoadMaster Active Suspension (RAS) / Bilsteins / K&N drop in
2007 JayFlight 31BHDS (2 slides 3 women just right! )
3rd Annual Excursion Diversion / Ford Rally 2010 here: http://www.ford-trucks.com/forums/88...ml#post7941270
  #82 (permalink)
Old 07-04-2009, 04:08 PM
tpierce941's Avatar
tpierce941 tpierce941 is offline
tpierce941 is starting off with a positive reputation.
Hey i just did my truck what difference, and a little fluid came out to. Its like a new truck with 90,000 thanks for the tip.
  #83 (permalink)
Old 08-29-2009, 03:57 PM
Rlbol Rlbol is offline
Rlbol is starting off with a positive reputation.
I have an 05 ex with 48000 miles. I was wondering if adjusting the steering box would help my problem. The steering seems great and most speeds except on the highway. at that speed there seems to be about an inch play in either direction. once past that it drives great. at slower speeds or going around a turn it is great. Any help or suggestions would be greatly appreciated! also it does have a factory rear sway bar.
  #84 (permalink)
Old 08-29-2009, 11:17 PM
VaSheriff VaSheriff is offline
VaSheriff has a good reputation on FTE. VaSheriff has a good reputation on FTE.
Here's the picture mannasteve was trying to show:
__________________
SQUIRRELS -- nature's little speedbumps!
  #85 (permalink)
Old 09-09-2009, 08:56 PM
VTcivil VTcivil is offline
VTcivil is starting off with a positive reputation.
I did this tonight and definitely helped. I need to get on the highway for a final check. Here is some additional information from my experience tonight that might help others. This was on a 2003 6.0 Liter Diesel model with 86k miles.
Hex key to use is 3/16ths
Lock nut is 5/8ths
Going from the bottom is too hard.
Take out air filter.
Take out front part of air box (on 6.0 diesel models)
Remove some of the snap on fan shroud to get better access to the adjustment screw. Just use screw driver to pry off snap on shroud in about 6 places.
I marked mine like the original poster and then just did one complete turn since mine was quite loose and it's about 90% better. Put it all back together and just test drove with good results. After a few hundred miles I might dial it in when I have more time.
  #86 (permalink)
Old 10-07-2009, 10:06 AM
Dakrri's Avatar
Dakrri Dakrri is offline
Dakrri is starting off with a positive reputation.
I tightened mine, but I think I either over tightened it, or I need to tighten it more. It’s had to control at 60 to 75 mph.
The weird thing is, when I’m exiting the highway ramp, and making a hard right turn, if I let go of the steering wheel it doesn’t spring back….I stays turned into the turn.
Anyone??
Thank you dakrri
  #87 (permalink)
Old 10-07-2009, 10:18 AM
04X 04X is offline
I had my ball joints replaced after finding almost all bad. The wandering that was starting to build is gone now.
  #88 (permalink)
Old 10-07-2009, 10:22 AM
Dakrri's Avatar
Hi o4-ex
I have a 105,000 on my truck and the ball joints were done at 83,000.
Thanks
  #89 (permalink)
Old 10-07-2009, 10:27 AM
04X 04X is offline
I was replying because I had posted in this thread earlier with a wandering problem, so my info was just a follow-up.
I had a couple ball joints replaced with Ford parts. A couple years later they needed replaced again. Moog are on there now.
Thanks,
Paul
  #90 (permalink)
Old 10-07-2009, 10:33 AM
Dakrri's Avatar
I'm wondering if after other FTE tighten their steering box up, if they too lost the spring back when in a curve.
I think I still need to tighen mine more. It sloppy to me at highway speed, but my wife says there is to much response in the steering.
Tags
2002 , box , duty , excursion , f250 , ford , heavy , play , stays , steering , truck , turn , turned , wander , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
