Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #46 (permalink)
Old 08-12-2008, 10:55 PM
1 Excursion camper's Avatar
1 Excursion camper 1 Excursion camper is offline
1 Excursion camper is starting off with a positive reputation.
I did the adjustment before the Hellwig install. and let me tell you it was very darty with the sterring being so responsive. after the Hellwig install it was like driving a go kart, albeit a 7500lb go kart. but still much safer to drive than stock!!!
  #47 (permalink)
Old 08-12-2008, 11:08 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
Never fry bacon NAKED!
2002 Ford F-250
My Garage
Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold
Quote:
Originally Posted by 1 Excursion camper View Post
... albeit a 7500lb go kart. but still much safer to drive than stock!!!
Wow, yours is light!
Mine weighs 8600lbs.
Stewart
__________________
The Brotherhood of FTE <~click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody
2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
  #48 (permalink)
Old 08-13-2008, 11:49 AM
PROSTOCK PROSTOCK is offline
PROSTOCK is starting off with a positive reputation.
One thing y'all might want to consider with these adjustments. The slop is from wear in and around the center of steering, where you spend much of the time driving....1/2 turn of the wheel from center area. There's little relative wear at the extreme's of turning. You don't spend much time at full lock so now all those adjustments you made are in actuality binding the box at the extremes of turning. I doubt many, if any, have actually been inside one of these units. If you have you'll see how a reciprocating ball rack works and why your "fixes" will just accelerate the wear. The real fix is to replace the whole gear box with a new one.
__________________
'65 F-250 Custom Cab 352FE 2WD
PS, PB, C6, 3.73 Dana 61('81 F350)
'02 Excursion Limited V10 2WD
Bilsteins, Tekonsha P3
  #49 (permalink)
Old 08-13-2008, 11:52 AM
Stewart_H's Avatar
2002 Ford F-250
My Garage
Quote:
If that turns out to be the case, so be it. But until then, I'm getting more bang for my buck by prolonging the replacement.
Stewart
__________________
  #50 (permalink)
Old 08-13-2008, 11:57 AM
dbtx dbtx is offline
dbtx is starting off with a positive reputation.
prostock, regardless if I've seen the inside of one of these boxes or not, that's some pretty strange logic.
Don't tweak the box you'll just accelerate wear, replace it instead?
Huh? If the steering doesn't bind after the adjustment and cause a safety issue, who cares?
I don't argue that the real fix is to replace the box, but if you put that off for another 20k miles by tweaking it, you saved money.
Doug
__________________
2008 Expedition EL 4x2 with heavy duty tow package
2007 F150 XLT SCrew 4.6L Black with Chrome package
Mods: Katzkin Dark Charcoal Leather Interior, Rubber Bed Mat
2005 Excursion 4x4 Limited V10 (traded on the Expy)
Mods: Helwig Rear Sway Bar
  #51 (permalink)
Old 08-13-2008, 12:07 PM
Stewart_H's Avatar
2002 Ford F-250
My Garage
Quote:
Doug, we think alike!
Stewart
__________________
  #52 (permalink)
Old 08-13-2008, 12:12 PM
Doh! You beat me to the submit button! =D
__________________
  #53 (permalink)
Old 08-13-2008, 12:20 PM
Stewart_H's Avatar
2002 Ford F-250
My Garage
Only by 5 minutes.
See? That's what happens when you take a 5 min break!
BTW, I did this fix back in December of '06. Just shy of 30K miles ago, and my rig is still running fine. So I've added 30K + miles to the life of my steering box.
I'm happy!
Stewart
__________________
  #54 (permalink)
Old 08-13-2008, 12:30 PM
I did mine before 20k miles and it was still good at 60k when we traded it in last month.
The Michelin LTX M/S tires we put on it last fall totally brought back the wander and I was never able to get it back to where it was with the stock BFG tires. That was one of the contributing factors to trading it in...
__________________
  #55 (permalink)
Old 08-13-2008, 02:47 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy X_Hemi_Guy is offline
X_Hemi_Guy has a great reputation on FTE. X_Hemi_Guy has a great reputation on FTE. X_Hemi_Guy has a great reputation on FTE. X_Hemi_Guy has a great reputation on FTE. X_Hemi_Guy has a great reputation on FTE.
I'm with Stewart and Doug...albeit 2+ hours after the bobsie twins! jk...
What would we replace our boxes with?...another OEM one that is prone to the same issue?...or spend big bucks on an aftermarket one when I can spend 5 minutes of wrenching to take out the slop like I did over 10K miles ago and the steering response is still as reactive as when I made my adjustment...although I didn't over do mine...I made 3 individual 1/4 turn adjustments to take out the play that caused a constant need for steering wheel inputs while towing...now I can simply place one hand at the bottom of the wheel and simply drive...
There certainly may be merits to Prostocks advice...and we may all be headed to a box replacement in the future...the difference is that our approach is a maybe spend money on a box replacement versus a certain cash outlay in Prostocks approach...I'll hedge my bets for the time being knowing that I may have prematurely wore out an already wore out steering box that I nurse along for another few years...
This is still one of the best threads on this forum...even though Doug abandoned us for that mini-Exursion he now drives! ...
we still love you man!
joe.
__________________
2005 Ex V10 4.30's
Hensley Arrow / Rear Hellwig / Prodigy Brake Controller / RAS / Bilsteins / K&N drop in / SCT X3 Tuner with 5-Star Tunes / Aeroforce Tech OBDII Digital Gauge / Hawk LTS Pads
2007 JayFlight 31BHDS (2 slides 3 women just right! )
3rd Annual Excursion Diversion / Ford Rally 2010 here: http://www.ford-trucks.com/forums/88...ml#post7941270
  #56 (permalink)
Old 08-13-2008, 08:33 PM
Group hug! Doh! Sorry, that's a different forum!
It is indeed a mini-excursion! It does tow my low-profile 7k gvwr travel trailer with 90% of the capability of the excursion. The Excursion teamed to an appropriately sized 6spd auto would be the heavyweight suv towing champ of all time! The 6spd in the Expy makes that V8 tow like a V9.9. I was truly amazed after my 1500 mile trip.
That said, I wouldn't dream of hooking up Joe's trailer to the Expy. That would be a deathwish. So, we're stuck with smaller, lighter trailers, but we're ok with that.
Yes, I drive an Expedition - "not that there's anything wrong with that", to quote Seinfeld
I do miss the "tick off the enviro-wacko" aspect that the Excursion had going for it...
__________________
  #57 (permalink)
Old 08-13-2008, 11:24 PM
AltaEx AltaEx is offline
AltaEx is starting off with a positive reputation.
I sure hope this thread gets added to every pre-existing wandering thread. I've noticed steering wheel play and think that is the cause of my Excursion's wandering.
Note: I've already done the tires (285 Wrangler Silent Armour) and ball joints added Helwig sway bars, Bilstein shocks, RAS and had an alignment done - and the Excursion is still a handlful when towing our 31 foot "lightweight" trailer.
It's probably just a steering box adjustment away from being a perfect tow vehicle.
  #58 (permalink)
Old 08-14-2008, 04:35 PM
It depends on how much adjustment you make...small adjustments are probably a great alternative. But several full turn adjustments and I think you are headed for a new box.
Why are they so prone to being sloppy in the first place? Do the pickup's have the same problem? Seems like building a decent gearbox would be fairly straightforward these days...they have remained essentially unchanged for the last umteen years. I would hope that a OEM replacement would be upgraded, but I am probably wrong there
__________________
  #59 (permalink)
Old 08-14-2008, 05:17 PM
All the feedback I have gotten is that new factory boxes are hit and miss if you get a tight one or not, and I think that is evidenced by the fact that mine was awful at 16k miles (as were many others around the forum).
Yeah, you'd think they could do it right by now, buuuuuutt we all know how big companies can work sometimes...
__________________
  #60 (permalink)
Old 08-16-2008, 01:40 PM
WJC WJC is offline
WJC is starting off with a positive reputation.
i did mine today, had to remove my k&n fipk to get to the steering box. not sure how many turns it took as i was too busy cursing and yelling due to lack of room in there.anyway, it made a huge difference, drives like its on rails. i did have a small amount of fluid come out when i losened the lock nut, is this normal?
__________________
2005 EXCURSION LIMITED 4X4 6.8 V10 K&N FIPK GIBSON EXHAUST Y-PIPE HYPERTECH MAX ENERGY PIONEER NAVIGATION AVIC Z-1 POWER SLOT CYRO ROTORS KOOLVUE MIRRORS CATCH ALL MATS MOBILE-1 37,000 MILES
Tags
2002 , box , duty , excursion , f250 , ford , heavy , play , stays , steering , truck , turn , turned , wander , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
