Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #31 (permalink)
Old 02-01-2007, 11:58 PM
JAY95gt's Avatar
JAY95gt JAY95gt is offline
JAY95gt is starting off with a positive reputation.
Question
Quote:
Originally Posted by S_Harvey
Mine too.
Mine is cocked slightly to the left.
Stewart
Thread digging - sorry. Interesting that my '00 is turned to the left when going straight too. Common issue? I thought maybe it was hit at some time but don't see any repaired damage. Did the tie rod adjustment clear it up for anyone (Seems it should)
__________________
Jay Schwarzmann - www.schwarzmann.com
83 Mustang GT - It's just a 5.0L
1.39 / 6.20 @ 112.8 / 9.692 @ 140.4 with 235 shot
1.63 / 7.06 @ 101.1 / 10.98 @ 125 N/A @ 3015 lbs.
2000 Excursion Limited 2WD V10
Tow vehicle and becoming a daily driver
110K miles+ and still kicking.
  #32 (permalink)
Old 02-02-2007, 12:36 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
Never fry bacon NAKED!
2002 Ford F-250
My Garage
Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold
Not yet.
I really need to take it in and see if a tie rod adjustment will fix it. But because it's one of those things we've lived with (read: the wife hasn't bugged me about it) it's on the back burner.
Stewart
__________________
The Brotherhood of FTE <~click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody
2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
  #33 (permalink)
Old 02-03-2007, 10:46 AM
shadowdd's Avatar
shadowdd shadowdd is offline
shadowdd is gaining momentum as a positive member of FTE.
Well, I guess I am going to give this adjustment a try. I have 159,000 + on my X and she does wander a little. I'll post the results when I get around to doing it ( myX is lonely at home while I am in Hawaii for 18 days).
Bryan
  #34 (permalink)
Old 02-06-2007, 11:47 PM
detroitfd's Avatar
detroitfd detroitfd is offline
detroitfd is starting off with a positive reputation.
Anyone have pics? I have an 00' PSD and it does wander a bit. I'd love to see what it is to fix it.
  #35 (permalink)
Old 02-07-2007, 12:16 AM
JAY95gt's Avatar
This may be a good one to add to the Tech folder *hint hint*
__________________
  #36 (permalink)
Old 02-07-2007, 11:11 AM
boertje boertje is offline
boertje is starting off with a positive reputation.
Just did mine too. Super easy to get to on the 7.3L. Only did 1/2 turn and that did the trick. I didn't have much play but more than I wanted...now its gone. I have 72,000 miles on my X.
  #37 (permalink)
Old 02-07-2007, 03:00 PM
4wheelexcursion 4wheelexcursion is offline
4wheelexcursion is starting off with a positive reputation.
Just finished my "repair" and what a difference!! A little difficult to get to on my 4x4 6.0, just pulled the air filter out of the way. I did 1 full turn clockwise on my 2003 with 50k.
Thanks again for this great tip
  #38 (permalink)
Old 02-08-2007, 02:34 PM
detroitfd's Avatar
Steering
Did mine today. What a difference!
But, I had to tighten mine about 1 full turn, which tightened it as far as it will go. So, at next adjustment, what's involved with replacing this?
Thanks!
  #39 (permalink)
Old 02-08-2007, 07:49 PM
I don't have an exact time for you but you should not have any problems for a long time. I would think the next step would be a new steering box.
  #40 (permalink)
Old 02-09-2007, 04:00 PM
cficare cficare is offline
cficare is starting off with a positive reputation.
Quote:
After tightening it "as far as it will go," a new steering box is not far off in the future. Adjusting a steering box takes a very ginger touch ... unless one likes replacing expensive pieces of equipment on a regular basis. Good luck y'all!
  #41 (permalink)
Old 03-12-2007, 09:44 PM
Col. Kurtz Col. Kurtz is offline
Col. Kurtz is starting off with a positive reputation.
Smile Much Better!!
Adjusted my gearbox tonight. Took 4 test drives, but I didn't want to go too much. 2001 6.8 4x4 w/ 85k took 1& 1/8 turns to get it right. This is a "feel" thing.
  #42 (permalink)
Old 04-20-2007, 04:32 PM
Strester's Avatar
Strester Strester is offline
Strester is starting off with a positive reputation.
2003 4x4 7.3 having the same problem, Guess Ill be under the hood this weekend
  #43 (permalink)
Old 04-22-2007, 06:38 PM
kappysworld kappysworld is offline
kappysworld is starting off with a positive reputation.
Smile Gear Box Adjustment
WOW whats a difference 20 Mins can make. Was simpler than I thought. Removed the air intake used a step ladder and bam was doen like that. 2000 EX with 75K mile took 6 1/4 turns feels great just like a new truck
  #44 (permalink)
Old 08-12-2008, 04:32 PM
Trailblazed's Avatar
Trailblazed Trailblazed is offline
Trailblazed is starting off with a positive reputation.
I'm bumping this one back to the top! After doing some research on the nearly 4 inches of slack either way in my steering, I came across this thread and it cured my problem! I thought for sure I was going to have to buy a new steering box after I checked everything else out for play (tie rod ends, ball joints, etc). I knew there was an adjustment on the boxes but I didn't think it would fix my wandering and extreme amount of play in the steering. After about 2 turns, I'm pretty close to perfect. Maybe another 1/2 turn and I should be good.
Hope this can be useful to others as it was to me!
__________________
http://i15.photobucket.com/albums/a4...100_1943-1.jpghttp://i15.photobucket.com/albums/a4...k/100_1949.jpg
02 F250 7.3L Supercab Lariot 4x4 loaded,8in ProComp Lift,Garrett Powermax Turbo,Jegs 4in exh.,BD Shift Kit,K&N Cold Intake,DP Tuner 80hp..XTRAS!
  #45 (permalink)
Old 08-12-2008, 05:27 PM
Deno346 Deno346 is offline
Deno346 is starting off with a positive reputation.
Another succes story. Had a 200 mile 1 way trip to Silver Lake Michigan with my wife,son, sister in law and her 2 kids with a fully loaded 30' Raptor toy hauler.... What a difference.
"BGOK BGOK, THANK YOU EASTER BUNNY"
All thats left to do now after ohhhhh everything on the front end is the sway bar bushings... they rattle.. But dang she steers straight...
Tags
2002 , box , duty , excursion , f250 , ford , heavy , play , stays , steering , truck , turn , turned , wander , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
