Cured my wandering steering - Page 13 - Ford Truck Enthusiasts Forums
  #181
Old 04-01-2012, 09:07 PM
campfire42 campfire42 is offline
campfire42 is starting off with a positive reputation.
I had my F250 front end aligned, and then had to loosen gear box back to where it was, maybe even looser, and truck has been steering like it ought to!
  #182
Old 12-19-2012, 06:38 PM
ATV PRO #11's Avatar
ATV PRO #11 ATV PRO #11 is offline
ATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to behold
Great post!!! Thanks to the original poster, I see it's helped ALOT of people!!
  #183
Old 05-05-2013, 07:37 PM
Mikei70's Avatar
Mikei70 Mikei70 is offline
Mikei70 is gaining momentum as a positive member of FTE.
I did this today and it made a big difference. It took about 3/4 of a full turn. It removed almost all of the play in the steering. Before I could turn the wheel about 30 in either direction before the wheels would respond, but now it is instantaneous.
Thanks to the dbtx for the original post and also to VaSheriff for the picture and Stewart for compiling the thread otherwise I might not have found it at all.
  #184
Old 07-10-2013, 01:06 PM
jlwpapa jlwpapa is offline
jlwpapa is starting off with a positive reputation.
Quote:
I had posted my problem on another thread, regarding looseness in the steering AFTER removing my old Silent Armor tires, changing to new LTX-MS2's, having it realigned and the front end checked! And after going back to Ford 3 times, the looseness was definitely in the steering wheel play!
Thank you to the one who started this thread as it not only solved my problem, but probably can still help many others! Had it adjusted 1/2 turn and the truck handles better than new, tracks beautifully with no loose play at all! It still amazes me that the old Goodyears somewhat masked the problem and that the new Michelins magnified it, but whatever, the problem is resolved. Thanks to this Forum and this thread, I saved the cost of a new steering box, THANK YOU ALL AGAIN!
  #185
Old 09-17-2013, 06:30 PM
ycis ycis is offline
ycis has a good reputation on FTE.ycis has a good reputation on FTE.
what a great thread, i was kicking myself trying to figure out why i had so much slop...yet all my tie rod ends looked solid.
  #186
Old 01-30-2014, 01:15 PM
Metalhead47's Avatar
Metalhead47 Metalhead47 is offline
Metalhead47 is gaining momentum as a positive member of FTE.Metalhead47 is gaining momentum as a positive member of FTE.
Did this last nite, and I'm wondering if I cranked mine down too much. I don't get any binding on tight turns, but the steering overall is much heavier (not sure if I'd say TOO heavy) and doesn't quite want to return to center going down the road. Pretty sure tightening the locknut cranked it down extra, I actually found the whole procedure a significant PITA. Truck was recently aligned but I'm sure my TRE's are due for replacement too.
  #187
Old 05-28-2014, 10:46 AM
JohnInCanada's Avatar
JohnInCanada JohnInCanada is offline
JohnInCanada is starting off with a positive reputation.
OMG! I just did this tweak; saved my butt! I'm so happy with the steering of my Ex. What a difference!!!!! Holy crap!
Mechanics and suspension shops wanted me to spend thousands of dollars on steering dampeners and other stuff.
Instead I spend $5 on a couple of Heineken; my neighbour and I put in 20 minutes of time; and we had another couple of Heineken. Tough night. WAY better than thousands of bucks on "stuff" that I don't need.
THANKS GUYS!
  #188
Old 08-11-2014, 06:07 PM
dudem3 dudem3 is offline
dudem3 is starting off with a positive reputation.
I've done a lot of work on a lot of cars and trucks over the years and never have I solved such a significant problem with something so easy as this.
I know this thread is 8 years old but I just bought my 2005 Excursion v10 4v4 a few weeks ago to use as a tow vehicle for a 29' travel trailer we just bought. After a white knuckle 2 1/2 hour tow this past weekend I started searching for what was wrong with the constant wandering and came across this thread.
I spent no money and about 10 minutes to adjust the screw with the allen wrench about 1/2 turn and it actually drives in a straight line now, amazing. My son took it for a ride the other day and could not keep it in a straight line. His constant adjustments were making me motion sick and now he can't believe how much better it is.
The full test will be in a month or so when we take the travel trailer out again.
  #189
Old 12-19-2014, 06:26 PM
II_Tall's Avatar
II_Tall II_Tall is offline
II_Tall is starting off with a positive reputation.
Thank you! Thank you! Thank you!
Huge kudos to the OP, DBTX!
I'm brand new to FTE. Just bought my first diesel. An '05 Excursion Limited 4X4 with the 6.0. Love it so far, and FTE was a huge part of making the decision to buy it! Only relatively minor stuff needed at this point, but the biggest concern I've had is what I found referred to on here as "wander".
I was starting to feel like I would be needing the rear sway bar, upgraded shocks and possibly front sway bushings. The only problem I was having with the plan was that my truck rides terrific! Good handling on corners. Little body lean, etc. The only issue seemed to be the constant correction required just to stay in the lane... without a load. Hmmmm....
Then I finally find this thread. The great news? It's MUCH better. Just took a test drive and boom... Holding steady as she goes! The only bad news is what it cost me.
Parts? $0.00
Labor? $0.00
New dress slacks because I was too eager to try this before I left the office to drive home? $60.00
But totally worth it! I was already enjoying the site. Now, I'm addicted!
DBTX, I don't know if your name indicates you live in Texas or not, but if you're in West TN anytime soon, inbox me. I'd love to buy you a beer!
BTW, Here's a pic of my new (now even better) ride.
  #190
Old 12-19-2014, 07:48 PM
gwh1bass gwh1bass is offline
gwh1bass is gaining momentum as a positive member of FTE.
My 05 Ex Limited 6.0 handles just fine on good roads, it's the crappy roads Michigan is known for where things are not so great. When the road is rough, it can be felt in the steering wheel and it will not track so straight. A bump in the road has the steering wheel slightly jerking and the truck follows. Could this be the infamous rear steer?
  #191
Old 12-20-2014, 07:25 AM
Paul Titus Paul Titus is offline
Paul Titus is gaining momentum as a positive member of FTE.Paul Titus is gaining momentum as a positive member of FTE.
At 200K I haven't noticed this problem with my Ex, but when I do I'll know where to start.
To the individual cringing at someone adjusting the steering box I honestly wonder have you ever mechanically worked on a vehicle? Even with all the computer stuff on vehicles today there are plenty of mechanical adjustments that can be done. If you're under the age of 40 it's likely you never adjusted the idle on a carburetor, points in a distributor, or valves for flat tappet lifters.
The steering box is likely a worm-gear drive system that the adjustment allows for varying tolerances in manufacturing and wear over time. They are factory spec'd but that may be just on the edge of good control so that after break-in time the mesh can be sloppy.
Cranking down on them without thought would be a NO NO, but following the OP instructions he warns the DIYer who will attempt this. Leaving the steering sloppy is not a good or safe option either.
It takes a lot to wear out a steering box, not just mileage, but poor road conditions jerking the steering in opposing directions. That is one reason the old vehicles had bad steering (besides substandard components or undersized). If you drive on the highway you're unlikely to do considerable wear to a box, but if you off road or travel highly uneven roads then a steering box will get more wear and tear and need adjusting.
Just my 2 cents on this topic.
  #192
Old 12-20-2014, 08:29 PM
Watcher58's Avatar
Watcher58 Watcher58 is offline
Watcher58 is a name known to allWatcher58 is a name known to allWatcher58 is a name known to allWatcher58 is a name known to allWatcher58 is a name known to allWatcher58 is a name known to all
I've about worn my butt out on this thing. I had an 01 for 10 years 2WD--had it new--never had problems that radius rods and rear hellwig stabilizer didn't fix. This is an 05 I just bought and it beats me to death. I replaced the steering stabilier, adjusted the steering box, supposedly the ball joints were replaced right before I bought it. I put Road Master suspension addition on...and it still wanders all over the place. Go around a curve on the highway and sweat will poor off of you. I ease into the curb once the wheel hits a certain point it seems to change to a different scale of movement and really reacts. Then I have to react and I get into this back and forth deal for 10 to 20 secs before I get it settled down.
It is really miserable to drive right now. I checked the front lug nuts and their torque was all over the place-some 3/4 ofa turn off---no help. I used a level on my sidewalls and appear to have negative caster--so will check all linkages again..there HAS to be some reason why this big pia is doing this. Hellwig sent the wrong u bolts for the rear stabilizer so it'll be a few weeks before that goes on--I'll let you know. Suggestions and blessings appreciated
  #193
Old 12-20-2014, 09:41 PM
timf150's Avatar
timf150 timf150 is offline
timf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud of
Quote:
You mentioned the ball joints were just replace. Perhaps its the "not returning to center" issue some have when the ball joints are new and are tight. Moog's tend to be tight when first installed.
Tim M
  #194
Old 12-23-2014, 06:53 AM
Watcher58's Avatar
I had ball joints on my first one which was 2WD--after playing with it a while which included some Landyot Radius Rods, I could drive it down the highway with one finger. I don't expect that with 4WD but this is a challenge. I might give the steering a light more firmness but it's more that it just doesn't want to stay straight down the road. I live in MT with crowned and wavy roads but they don't have this much crown. Guess I'll see weher it's front ot back after I bolt on the sway bar but after the Roadmaster suspension it doesn't jump off in a direction after a bump--Radius rods cured that in the 1st one. Radius rods are more fundamentally sound but the only REAL ones you can get since Landyot stopped production will run you 700 to 900 dollars.It almost seems like the front end shifts like it's saying "Naw-I wanna go over there now--oops sorry I meant over there" Like I say, there is an anwer. I just hope I don't have to replace every freaking thing under the front end. It would help if the nearest REAL mechanic wasn't 70 miles away. I'm doing stuff I haven't done before and when I bought this I knew it would have some projects--even with only 82K on it. I just like to do something and have a result
  #195
Old 12-23-2014, 12:21 PM
timf150's Avatar
Watcher58...
One of the updates people do when their X has the wandering issues is to change the front leaf springs to v-codes. The current ones are a bit soft and don't do a good job supporting the front end. You added a RAS to the rear so I don't think you need to look into change the rear springs to b-codes.
Do you know if your front leafs are the original ones?
Tim M
Sticky steering, not returning to center Scoob5555 Excursion - King of SUVs 19 07-28-2016 10:43 AM
steering box adjustment? texasjack 1999 - 2003 7.3L Power Stroke Diesel 17 04-07-2015 11:14 AM
'77 F250 Steering box adjustment olblue77 1973 - 1979 F-100 & Larger F-Series Trucks 7 12-22-2014 10:30 AM
Steering Play - Is this adjustbale? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 3 11-21-2014 06:48 PM
Steering box adjuster screw jammed, plz help Metalhead47 Excursion - King of SUVs 3 02-02-2014 04:57 PM
Tags
2002, box, duty, excursion, f250, ford, heavy, play, stays, steering, truck, turn, turned, wander, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
