help replacing valve cover gasket
i rebuilt the engine about a year ago, and everything has ran decent since then. a couple of weeks ago, my valve cover gasket started leaking oil, oil drips onto manifolds, burns off in smelly smoke.
yesterday i replaced the gasket, got a fel-pro rubber gasket, used permatex (the blue kind), torqued each bolt to about 100 inch pounds.
today its still leaking and it looks like part of the gasket is smushing out.
what did i do wrong? i was wondering if maybe using permatex with a rubber gasket was a bad idea..maybe it just lubbed it up to squish out.
sounds like you over tightened the bolts, the felpro rubber gasket is pretty firm so squishing it out isn't that easy. Using sealer does help, you just need to let it cure partially before putting the bits together, otherwise it can ast as a lubricant and allow the gasket to slip out of place as you tighten the bolts.
yesterday i pulled the valve cover off, and sure enough, that gasket was broken and pushed out of the way. I'm sure part of the problem was that i over torqued it a bit, but i think that combined with the lube on it is why it broke. i installed it dry this time and so far everything works well!
I used to have trouble with my valve cover gasket leaking. Then I realized that I was overtightening the bolts WAY too much. Since I figured out that it was my fault all those years, I just snug them up enough that they won't back out with the engine vibration.
It hasn't leaked in years! :P
I used just enough glue to make the gasket stick to the valve cover. I also noticed, (after my second try) that if the surfaces aren't dry enough oil can get kind of ornery in preventing good contact and allowing the gasket to properly seal. Never seems to be a really good way to get all the oil off though.
Originally Posted by Lone Wolf #2
The best way I have found is to wipe the surfaces down with brake cleanerand using a valve cover stud kit.
Does a stud go in every hole?
Where do you get them?
What kind of nut fastens the cover down? Do you use lock washers?
Wonder if the studs would interfere with the Fuel injection set-up above the Valve cover?
jaco
