Turbo 3.0, 2005 ranger
Old 07-07-2006, 10:47 PM
RacinNdrummin's Avatar
RacinNdrummin
RacinNdrummin is offline
Im thinking about putting My .60/.48 T3 turbo on my 2005 ranger 3.0. I have checked the compressor maps and the .60 seems to be right in where I want it with 73% efficiency at 3500-4000 RPM with a pressure ratio of about 1.50(7 psi at sea level). I think my Hot side may be a little small for the V6 but will work as the engine is stock. My question is: What should I do about fuel delivery? I was thinking of upgrading to 19lb injectors and a MAF from a 5.0 explorer but im not sure the fuel pump has the flow that I want. I would think that the fuel pump from a ranger should be the same as a fuel pump from an explorer, but im not sure. I also could go the route of an FMU, but again, pump issues come up, will the pump have enough pressure? What should I do in this case?
Old 07-08-2006, 08:25 PM
RacinNdrummin
ok, i just looked at the turbo and it is a .60/.63, not .48 as I thought.
Old 03-21-2010, 04:34 PM
Flyguy763's Avatar
Flyguy763
Flyguy763 is offline
Want to Turbo charge my b-3000
It has the same engine as the ranger. Have you finished turbo charging your ranger and how sucessful was it.
Bsnith
1983 - 2012 Ranger & B-Series
15
06-16-2013 12:08 AM
braeden50
05-10-2013 08:33 AM
undertow91
05-06-2010 07:15 PM
v8rangerboy
09-14-2006 10:55 AM
fulton
06-07-2000 07:07 AM
Quick Reply: Turbo 3.0, 2005 ranger
