Need some help
Need some help
Hello! I am new to this website. I need some help. I have a 1970 f250 4x4 that I recently purchased. Are there any aftermarket power steering or power brake kits available for the truck? Are there any other Ford parts from different years that may swap onto my motor? It has a 360 under the hood with a 4 speed manual tranny. It also has 4 wheel drum brakes.. which was pretty much the standard in those days. I think that I may have seen power brake boosters available for it in a catalog somewhere... but I am not sure if that applied to my truck or not. Any help would be greatly appreciated. Thanks!
James
James
Need some help
There are a few more issues to deal with, on adding PS to a 4X4 because of different front drives. The brackets, and pump should be easy to come by in your local salvage yard. If the 4X4 is like the 2X4 you will need to get the steering column as well. Look for one with the same style tranny as yours, so the column will match up.
If you consider power brakes at all go with the disks. It's a much better stopping system.
John
jowilker
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
John
jowilker
66 F100s
Guntherexpress
08-14-2015 11:45 PM
Bluebirdz22
05-14-2002 10:31 AM
