Removal of door plastic panel
Old 07-06-2006, 01:28 PM
chopperpilot69's Avatar
chopperpilot69
chopperpilot69 is offline
Can anyone tell me how to remove the plastic panel on the pilot door without breaking the inside tabs.
Old 07-06-2006, 02:36 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Welcome to the forum
1) pop out the long strip at the top of the door on the rear above the panel.
2) pop out the window/door lock control panel (if equiped)
3) pop out the trim piece behind the door handle
4) remove the screws hidden behind the pieces that you have removed
5) pull straight up on the panel about 1" and it is off. These do not use pop in clips, that have tabs that go down into slots in the door.
Old 07-06-2006, 09:54 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
on my 2001, there are three sheetmetal screws at the bottom edge of the panel into the door. next take the plastic trim off around the door handle and the power window control panel, two screws hidden behind that. last, llift the panel up an inch line like LX said. I have heard others talk about the "top stirp". mine has none, there must be some variation between years.
