4x4 selector switch bulb
Im not 100% sure about the 4X4 switch, but I've had the cruise control on/off switch burn out before and the dealer told me I'd have to replace the entire switch for around $60. That was 8-9 years and 3 Rangers ago so I'd guess its more then that now.
Im going to go out on a limb and assume its going to be the same for the 4X4 switch. But let us know what you find out.
When I pulled the headlight switch off to check it out, I noticed that the bulb could be taken off the switch assembly easily. When I went to the dealer, the bulb was listed on the drawing. If the bulb is inside the switch, as in the case of the cruise control switch, you probably won't be able to get it from them seperately.
-Jim
-Jim
FD5150
15
10-10-2016 08:54 AM
EDsurvivor
10-04-2016 09:54 AM
4x4_EB_Explorer
02-21-2002 10:19 AM
