Supercharger for a 2003 4.0L Ranger? - Ford Truck Enthusiasts Forums
Old 07-05-2006, 10:21 PM
AceTheLegend AceTheLegend is offline
AceTheLegend is starting off with a positive reputation.
Yes i was wondering if anybody could point me to where i can find information for superchargers or turbos for my ranger. Also if there are any other performance boosting things i could do to the engine or any other component that would help me boost hp and torque would be great.
Old 07-08-2006, 06:36 PM
FtwoFityboy06 FtwoFityboy06 is offline
FtwoFityboy06 is starting off with a positive reputation.
Old 07-10-2006, 03:58 PM
pud pud is offline
pud is starting off with a positive reputation.
Id say the easiest and cheapest supercharger for your truck is an Eaton M-90 off a supercoupe T-bird. Not the best option, but when you weigh in performance gain vs $ spent...its worth consideration. You can pick one up for $200-$300-ish on ebay sometimes with the harness and bigger injectors. Once I saw one with the harness, injectors, and computer for $450.
Old 07-11-2006, 07:47 PM
littleme13's Avatar
littleme13 littleme13 is offline
littleme13 has a good reputation on FTE.littleme13 has a good reputation on FTE.
the only problem with the eaton m90 is the manifolds are different so you have to fabricate something to hold the supercharger and the way they are shaped and mount its a pita imo. all thou like pud said if you can fabricate and want to go that route the m90 would be a good choice. you can even get the thing ported to flow more. and on the supercoupe they run 12 psi stock so that should be plenty for your 4.0. i belive that one of the bigger companies makes one. if im not mistaken vortech offers a kit if your not into looking to fab anything yourself. i just googled for 4.0 ranger superchager and it was vortech from summit that has the kit.
Old 07-12-2006, 04:42 PM
Yeah well i know a engineer that works at Eaton so i was trying to see if he could get me more info on the superchargers. I had tried looking at vortech but i only found superchargers for the Mustangs! ANyways, I figure if i do get a supercharger i am going to have to beef up my engine to take all that extra stress. What things besides cams and pistons should i consider changing?
Old 07-12-2006, 05:58 PM
littleme13's Avatar
having the heads ported usually helps with more airflow to compliment the supercharger. if your looking to tear into the bottom end to change pistons i would look into a good set of rods and myabe crank if they make one forged. also a girdle jsut to be on the safe side. of course all this depends on the money you wanna spend and how long you want the motor to last. ive heard that a 4.6 throttle body will fit onto the 4.0 but not positive on that one same with maf if your looking to do the intake also.
tony
Old 07-13-2006, 09:32 PM
I have already ordered the AEM Brute force air intake. Just waiting for it in the mail now and i figured the throttle body would be a quick few horsepower, but not sure whats a good buy, you know something that actually works. I figured MAF sensor when i have the money for it as well. I have tried finding a pulley set for my ranger but i can't seem to find someone that makes it for the 4.0L engine. Be great if there was an all ranger supplier or something like what some do for like the mustangs and such lol. Any other suggestion are great and thanks for all the input you have given me so far.
Old 08-25-2006, 06:38 AM
Bob Jusnes Bob Jusnes is offline
Bob Jusnes is gaining momentum as a positive member of FTE.
Sorry, this post is kind of old. We have pulleys and many other performance parts for your ranger, all we deal with is Ford Trucks (no mustang parts here, though we do dabble with Fusions...)
As far as the supercharger, Explorer Express makes a whole kit that will bolt right on to your truck. Its not cheap, but then again any good supercharger kit will cost you a few bones.
Nobody makes a MAF for the ranger anymore, according to Granatelli its because they could not maintain accurate readings. A throttle body MAY help, but i would look at a BamaChips programmer, Efan, Pulleys, Headers, Exhaust, etc, if you want to get some more power out of that truck!!
Old 08-25-2006, 06:18 PM
I have seen the explorer express webpage....and i know a guy that works at eaton so i am trying to see if he knows of a way i can get a deal on one of those superchargers. Anyways appreciate the input!
Thanks
AcetheLegend
Should i turbo charge my ranger or centrifical supercharger it Josh Lee Ponish Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 0 12-28-2015 10:19 PM
idea for an efi 300 six cyl supercharger.. 70torino429 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 11 07-13-2015 06:35 PM
f250 to gt500 ajax66 1999 to 2016 Super Duty 9 10-14-2011 12:00 PM
idea for an efi 300 six supercharger.. 70torino429 Ford Inline Six, 200, 250, 4.9L / 300 36 10-11-2010 09:22 PM
460 efi supercharger kilbrethj Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 1 07-04-2007 07:10 PM
Tags
2003, 2004, 2005, 40, 40l, 60, adapter, ford, kit, put, ranger, supercharger, system, times, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
