firing order on 2003 f-150 Triton 5.4L - Ford Truck Enthusiasts Forums
Old 07-05-2006, 09:39 PM
jeange jeange is offline
jeange is starting off with a positive reputation.
I was just wondering, whats the firing order on a ford I think its 1,2,3,4 on left side and 5,6,7,8 on right side is that the way it works on a ford?
Old 07-05-2006, 11:02 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Welcome to the forum
4 8
3 7
2 6
1 5
front
Old 07-06-2006, 07:57 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Quote:
Ford's convention is to assign left and right as if the viewer were sitting in the driver's seat (non-transverse mounted), not standing in front of the bumper.
Add that to LxMan1's tip and you're set.
Steve
Old 07-06-2006, 10:51 AM
99ExpyProblems 99ExpyProblems is offline
99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.
you want the firing order, or the plug placement? They have pretty much covered it above for plug placement. RH would be the passenger side.
Firing order, if it hasn't changed from 99 - 2003 is 1-3-7-2-6-5-4-8
Old 07-06-2006, 06:13 PM
FWIW, firing order on these engines in pretty much no longer relevent since you don't have a distributor to connect plug wires to.
Now, it's just a matter of making certain the connectors are just plugged in for COP systems. The older 4.6s, of course, do need to have the plug wires connected to the correct coil terminals.
Steve
Old 07-06-2006, 06:28 PM
ya thats what I ment the plug placement, because i got a misfire on my truck right now and wanted to make sure what cylinder is what.
Wrong firing order?? 370 4v earthman 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-19-2011 03:21 PM
firing order and rotation rickmc2 Ford Inline Six, 200, 250, 4.9L / 300 1 10-29-2008 12:07 PM
firing order cotterpin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-27-2008 10:16 PM
Need Firing Order Dan Russell 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 10-19-2003 03:33 PM
Firing order of 2000 Expedition 4.6L DallasCobra Expedition & Navigator 1 09-07-2003 10:01 PM
Tags
03, 05, 06, 2001, 2003, 24, 54, 54l, f150, fireing, firing, ford, order, triton, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
