Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-03-2006, 12:05 PM
pud pud is offline
Garage is empty, add now
pud is starting off with a positive reputation.
Blow through turbo set up with propane????
I know if you do a blow though set up with a carb'd gasoline engine you have to seal the carb up and replace the floats....but can I do a blow through set up with propane? ....Blowing boost through the mixer, will it handle the pressure?
Has anyone in here turbo'd their propane powered vehicle?
__________________
1987 muteg GT T-Tops
  #2 (permalink)
Old 07-10-2006, 03:17 PM
fraso fraso is offline
fraso is starting off with a positive reputation.
Blow-through turbo propane systems are quite straight-forward. In a blow-through application, the propane converter must be pressure-referenced to the propane carburetor. Some examples:
Turbo 1987 Ford Fairmont Ghia
Turbo Propane 1970 VG Valiant
Twin Turbo 1957 Willys
1984 Nissan Skyline R30, Turbocharged & Intercooled
1983 Mazda RX-7 LPG Turbo
Please note that some of the examples do not meet NFPA 58 requirements (e.g., illegally using forklift DOT fuel tank in a motor vehicle, etc.).
Tags
blow, carb, carburetor, conversion, fairmont, ford, lpg, propane, set, setting, setup, truck, trucks, turbo, twin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
