Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2006, 08:15 PM
BlueOvalFitter BlueOvalFitter is offline
BlueOvalFitter is starting off with a positive reputation.
Question Pics of the IMRC acuators
Does anyone have pics of these? Lower intake pics?
__________________
2007XL R/Cab,4.2 V6,auto
The anticipation of death is worse then death itself!
  #2 (permalink)
Old 07-03-2006, 03:38 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
I don't have a pic. Actually it will be hard to get a pic with the engine in the truck and the hood installed. You can really only see them from the firewall side of the engine.
I'll see if I can find something somewhere.....
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #3 (permalink)
Old 07-03-2006, 05:28 PM
Thanx Brian,I should have been more specific.I actually meant does anyone have a pic of a 4.2 engine,out of the truck,which shows the back side of the engine,or there lower intake off of the engine.
__________________
  #4 (permalink)
Old 07-04-2006, 10:12 AM
BrianA's Avatar
Well, no luck.
I think my Haynes manual has a pic in it. Maybe I can find it, scan it and send it to you.
What's the problem with yours?
Stuck open code?
Stuck closed code?
__________________
Brian A
  #5 (permalink)
Old 07-04-2006, 10:19 AM
Brian,thanx for the reply.I have a Haynes manual too and it shows the manifold with the IMRCs.But i'm looking for more in detail photos.And yes,I got codes P1537,P1538; IMRCs stuck open.I've looked for vacuum leaks now for over 4 days; no luck.I'm bringing it to the dealer this Saturday!
__________________
  #6 (permalink)
Old 07-04-2006, 04:49 PM
bokker bokker is offline
bokker is starting off with a positive reputation.
hi, picking up both threads-i have searched the chilton manual and there is not a picture to help you but checking the vacuum diagram. the pipe color is not black it is infact blue.this can be seen (on my engine) on the left hand side of the manifold below the primary battery fuse box, towards the back. it can be pulled off. the pipe (blue) shares its rubber boot with another pipe. the way i checked to see if i could open the manifold flaps (rails) was to put a plastic drinking straw into the rubber boot leading to the blue pipe and suck.
on doing this i could hear the flaps snap shut when i stopped sucking( all this without the engine running).
if you can hear them moving then there is a problem with no vacuum.
if they do not move then it will be a big stripdown, lower manifold off to get to them.
again i hope this helps. bokker.
  #7 (permalink)
Old 07-04-2006, 04:58 PM
Thanx bokker,i'm going to try that now! I'll post the results soon!
__________________
  #8 (permalink)
Old 07-04-2006, 05:29 PM
Bokker,I used some vacuum hose with a fitting to fit the blue line going to the IMRCs.I then sucked on the line not hearing a dayum thing!
Do you think they are bad?
__________________
  #9 (permalink)
Old 07-04-2006, 07:59 PM
BrianA's Avatar
BOF,
I can't say for sure but it seems like I have a vauge recollection of somebody's IMRC being physically stuck. Maybe due to deposit build up over time. Have you tried running some Seafoam thru the intake to see if that might free them up?
FWIW, I'd use the vacuum port just in front of the throttle body rather than the brake boost vacuum line.
So I guess it's safe to assume you don't have a vacuum problem since -as I understand it- the electrical solenoid applies vacuum above 2500/3000 rpm to open the IMRC butterflies. So, since the code is indicating stuck open, then loss of vacuum should not be the problem (as bokker mentions).
Here's a thought....
What if the electrical solenoid is bad and causing the IMRC to open all the time. Can you pinch off (or leave disconnected) the vacuum line going to the IMRC control. If the solenoid is bad, the valves will stay closed.
With the engine idling you could release the pinched off line (or reattach it, whichever way you do it) to see if the IMRC valves open.
Does this make any sense, what I'm trying to explain?
maybe the valves are not stuck open. Maybe they are being told to open when they should not be.
Of course all this is just another way to verify what you think you have already determine using the soda straw. But, in this case, I think a backup verification would be nice.
Remember Travlnman (Thomas) who used to hang out here? He sold his truck to buy a Ranger (mpg issue). Let me see if I can get in touch with him. He did all the work himself replacing intake manifold gaskets so he'll have first-hands-on experience.
Maybe he can help out here.
I'll try and call him and ask for his help.
Let's stay on this one. I'd like to help you and find out what the problem is.
OBTW, Thanks much bokker. Your input is always appreciated!
__________________
Brian A
  #10 (permalink)
Old 07-04-2006, 08:07 PM
Brian,i've done 2 applications of the SeaFoam treatment thru that vacuum port.I'm taking it to the dealer this Saturday.
__________________
  #11 (permalink)
Old 07-04-2006, 08:12 PM
BrianA's Avatar
Oh well.
Let us know what they find.
OBTW, I'll be in Clearwater all next week.
Seffner's close to Tampa isn't it?
My son's baseball team is playing in the IBC World Series (14 year old).
We'll be in Tampa one day doing the Busch Gardens thing.
Be on the lookout for me!
__________________
Brian A
  #12 (permalink)
Old 07-07-2006, 04:28 PM
blueovalfitter, i have just re read your answer about do you think they are bad. it has to be yes but as brian points out there is an electric solonoid that gives the signal that may also have gone bad.
it will be interesting to find out how the dealer cures your problem.
given time the only way i would progress is to take off the upper intake manifold and physically try to open the flaps. please keep us informed. bokker.
  #13 (permalink)
Old 07-07-2006, 04:45 PM
Unhappy
It's going to the dealer at 7:00 am in the morning.Here's a breakdown on parts and labor,if the IMRCs have to be replaced;
IMRCs X2= $156.00 each
Upper intake gasket= $13.50
IMRC bushings X2=$4.50 each
Shop fees= $25.00
Labor- if charged fleet rate 3 hours @ $75.00 an hour
Labor- if charged flat rate 3 hours @ $90.00 an hour
Diagnostics test - $90.00
Florida tax- $.07 on the dollar
I had to sell a Ruger Mini-14 rifle to pay this.My savings and checking accounts were wiped out 2 weeks ago for attorney fees for a legal matter in the family.
__________________
  #14 (permalink)
Old 07-08-2006, 03:08 PM
Exclamation
WOOOOOOOHOOOOOOOOO! ITS FIXED!
I can't even tell the engine is running!
Here's the breakdown;
IMRCs - $150.12 each X 2
Bushings - $4.27 each X 2
Upper intake gasket - $13.00
Labor - $297.95
Shop fees - $25.00
Tax - $45.16
Total: $690.09
__________________
  #15 (permalink)
Old 07-08-2006, 05:28 PM
pleased for you.
Tags
2000 , 2002 , 2003 , 42 , actuator , control , delete , dorman , f150 , ford , imrc , intake , manifold , pics , picture , ranger , runner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
