1971 F100 4x4 upgrades - Ford Truck Enthusiasts Forums
Old 07-16-2000, 10:44 PM
cranium_slayer cranium_slayer is offline
cranium_slayer is starting off with a positive reputation.
I have a 1971 F100 Custom 4x4 with an open knuckle Dana 44 front end, and I have read about converting it to power steering, as well as power disk brakes. How would I go about this? What years can I easily interchange the parts? I know the gear box has to be torn apart and something switched so the box can mount in the stock possition, what is that? Thanx in advance for the help.
Old 08-20-2000, 09:08 PM
dinosaurfan dinosaurfan is offline
dinosaurfan is gaining momentum as a positive member of FTE.
Hi there- I put power steering on my '71 4wd in '87, following instructions from some iowa farmer named Ibeling. The change involved some cutting and welding,and the installation of a steering box from a 3/4 ton van. I did my after the stock box broke as Iwas going down the highway, apparently it couldn't take the stain of turning my 38's. Scared the crap out of me as I went off into a cornfield unable to steer, no other damage to truck, the conversion went on just fine even tho it already had a trailmaster lift.Ibeling's instructions also explain how to make sure you don't lose turning abilitywhen lifted and don't have bumpsteer. If you can't find Mr Ibeling let me know and I will dig thru my papers and see if I still have his instructions. I recently purchased an open knuckle axle w/ disk brakes,am hoping to swap them on to my drum brake axle, will let you know. DinosaurFan
Old 08-20-2000, 09:38 PM
Nathan Nathan is offline
Nathan is starting off with a positive reputation.
1971 ford f100 Amccoach 1967 - 1972 F-100 & Larger F-Series Trucks 4 09-10-2015 01:25 AM
Shipping my vehicle with no key 1971F100 1967 - 1972 F-100 & Larger F-Series Trucks 4 11-06-2014 01:43 AM
adding power steering to 1971 F100 302 snapy64 New Member Introductions 4 05-22-2014 12:32 PM
adding power steering to 1971 F100 302 snapy64 1967 - 1972 F-100 & Larger F-Series Trucks 3 05-07-2014 09:27 PM
1971 2wd front axle swap to a 4wd cargoof 1967 - 1972 F-100 & Larger F-Series Trucks 3 09-03-2013 12:16 AM
Tags
100, 1971, 4x4, 71, box, brakes, converting, disc, f100, ford, half, interchanges, power, steering, ton, truck, upgrades
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
