Anyone in Monroe
as far as the slicks are concerned there is no inspection visual or otherwise. I live in lexingon meself so i know nothing about your area as far as the other things go.
this pdf file (posted below) located at http://www.ncdot.org can shed some light for you on the inspections though. there is http://www.ncdot.org/dmv/moving/newnc/emissions.html which has the counties listed current and future listings.
http://www.ncdot.org/dmv/vehicle_ser...nforcement.pdf
this pdf has all the information you need, i would try to find it, but i really need to try to finish buffing my truck today so its not so funny looking at work tomorrow..lol
ok I did a little research...
Looks like you have the full boat of emissions testing there..
here is the first line mentioning union country (if im correct is where monroe is)
Here is excerpt from that pdf.
Code:
In addition to the required safety inspection, all gasoline-powered motor vehicles which are registered or based in the initial nine (9) emission counties (Cabarrus, Union, Wake, Durham, Orange, Guilford, Mcklenburg, Forsyth, Gaston) and which are fewer than 25 model years old and up to 1995 model years old shall have an exhaust emission test. This emission test is in addition to the safety inspection required in the rules in this Section and shall be administered as a part of the regular inspection. The emission readings resulting from the test must be at or below the standards as set forth in Section 6 of this section or a waiver must be issued by the Commissioner of Motor Vehicles or their designated agent (DMV Inspector/Auditor). G.S. 20-183.2 Vehicles to be Exhaust Emission Tested Effective January 1, 2002 through December 31, 2005: • January 1, 2002 inspect 1976 model year vehicles up to 1995 • January 1, 2003 inspect 1977 model year vehicles up to 1995 • January 1, 2004 inspect 1978 model year vehicles up to 1995 • January 1, 2005 inspect 1979 model year vehicles up to 1995 Vehicles to be OBD Tested Effective July 1, 2002: • July 1, 2002 inspect 1996 model year vehicles an
By the way, here is the table
<TABLE cellSpacing=0 cellPadding=7 width=466 border=1><TBODY><TR><TD vAlign=center width="24%" height=57>
VEHICLE CLASS
</TD><TD vAlign=center width="21%" height=57>
MODEL YEAR
</TD><TD vAlign=center width="30%" height=57>
</TD><TD vAlign=center width="25%" height=57>
</TD></TR><TR><TD vAlign=center width="45%" colSpan=2 height=27>
Light-duty Vehicles:
</TD><TD vAlign=top width="30%" height=27>
</TD><TD vAlign=top width="25%" height=27>
</TD></TR><TR><TD vAlign=top width="24%" height=29>
</TD><TD vAlign=center width="21%" height=29>
1976-1977
</TD><TD vAlign=center width="30%" height=29>
</TD><TD vAlign=center width="25%" height=29>
</TD></TR><TR><TD vAlign=top width="24%" height=25>
</TD><TD vAlign=center width="21%" height=25>
1978-1979
</TD><TD vAlign=center width="30%" height=25>
</TD><TD vAlign=center width="25%" height=25>
1980
1981 & Later
</TD></TR><TR><TD vAlign=center width="45%" colSpan=2 height=29>
Heavy-duty Vehicles:
</TD><TD vAlign=top width="30%" height=29>
</TD><TD vAlign=top width="25%" height=29>
1976-78
1979 & Later
</TD></TR></TBODY></TABLE>
This is my field. All 1995 and older, under 1 ton, get a safety inspection only. 1996 and up only get an obd2 test. If a check engine light is on you fail, if not you pass. Also the safety inspection on 1996 and newer. The tailpipe test is over and done with as of July this year. This is the entire inspection....
