E350 rear brake drums
Originally Posted by trike1946
I have a 96 E350 DRW. Do the rear brake drums come off without a puller? Is there anything tricky about the rear brakes, other than getting the drums off. I tried to just pull them, but it didn't look like they were coming off. Thank you for any help.
After you remove the tires make sure the side you are working on is higher than the other side so oil does not run out.
Put a pan under it for the oil that runs out.
Put down papers to set the drum on for the oil.
Remove bolts (1)
Pull out Axle. (10)
Remove Axle nut. (9)
Take out bearing. (8)
Remove Hub. (7)
If you want a complete outline of this email me your email address and I will email you the information.
Back off the adjuster as stated above. It may help to turn the drum/axle as you pull on the drum. As also stated above, drums rust stuck to the axle. You may need to pry out on the drum and knock the axle back in at the same time. PB blaster, etc can't hurt.
Your axles and hubs should be separate parts but could have been swapped with older integrated units. Also stated above.
Stuck drums are one of the wrestling-match operations on vehicles.
gthbryce
29
06-01-2021 11:13 AM
bmiller44685
1983 - 2012 Ranger & B-Series
07-12-2008 09:05 PM
