97 powerstroke water pump remove and install - Ford Truck Enthusiasts Forums
Old 06-29-2006, 09:17 PM
davo303 davo303 is offline
davo303 is starting off with a positive reputation.
Wondering if there are any tips or shortcuts to remove and replace my water pump on my 7.3. Mines leaking out of the weep hole and i have a replacement to go in. Do I have to bleed the system after it's together? Any suggestions would help.
Old 06-29-2006, 09:32 PM
BodegaErik BodegaErik is offline
BodegaErik is starting off with a positive reputation.
This was the next question I was going to ask...... never had a problem with my 97 F250 and right now I have glow plugs and a water pump to replace. Already have the parts, so any answers to this water pump question would be helpful to me also. Thanks.
Erik
Old 06-29-2006, 09:46 PM
Todd525's Avatar
Todd525 Todd525 is offline
Todd525 is starting off with a positive reputation.
really nothing to the water pump. Its a snug fit, but nothing you shouldnt be able to do in about an hour or less, depending on your mechanical abilities. fill it up after you get er on, correct blend for your cavitation problem, go like heck... havent done glo plugs on any psd yet.... Cookie, Kwik???
Old 06-29-2006, 09:53 PM
plowhand's Avatar
plowhand plowhand is offline
Playing in the Dirt
plowhand has a good reputation on FTE.plowhand has a good reputation on FTE.
Once again: "Guys, find a post by 1997F-350, at the bottom of his post is a picture of his truck, next to that is "got manual" in blue. Click on it and it takes you to a shop manual."
Check down about halfway in this forum, they just discussed the water pump. Also do a search for water pump and you will get more info that you can handle.
Rent the fan clutch wrench set, and add the SCA when you refill.
Glow plugs answered in BodegaErik's other post.
Old 06-30-2006, 04:49 PM
water pump replaced
Thanks for the advice guys. One thing I must say is you will need a clutch fan wrench to remove the fan, rented it at crappy tire. I found my original thermostat rubber was tore and allowing coolant to bypass , that's why I couldn't make heat and it was hard on fuel. Replaced all the stock hose clamps with the screw type. I refilled it and cranked the heat and let it get up to temp with no air locks. Phew. My one ton idles and cruises so much better. Now I have to find out why I have crank vent oil coming out my dipstick...anything?
Old 07-01-2006, 06:52 AM
warpdriv warpdriv is offline
warpdriv is starting off with a positive reputation.
I rented my clutch tools at autozone. Free rental.
Also, put a piece of cardboard between the clutch fan and the radiator. That way when it falls from taking it off, it will not scar the radiator fins.
Got my water pump from O'Rileys. It had the thermostat gasket. Others have posted they had to buy one.
Have fun...
Old 07-03-2006, 12:21 PM
pucko94.5 pucko94.5 is offline
pucko94.5 is starting off with a positive reputation.
Quote:
Do you have oil coming out the dipstick tube or just venting air?
Water pump replacement on a '92 460 - a few questions SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 48 08-22-2014 01:57 AM
can't remove water pump - ideas? flapbreaker Cooling, Heating, Ventilation & A/C 2 08-01-2014 08:24 AM
(82) 4.9 water pump removal chermansr 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 11-01-2013 03:22 PM
Water pump replacement on 1987 6.9 Diesel dyoungen Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 07-27-2009 08:57 PM
water pump to intake manifold hose arsleuthster FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 09-09-2004 03:40 AM
Tags
2000, 73, 97, f250, f350, install, power, powerstroke, pump, pyro, removal, remove, replacement, stroke, thermostat, water, waterpump, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
