2.3 common oil leak?
Old 06-29-2006, 09:01 PM
nhswrld's Avatar
nhswrld
nhswrld is offline
so i have this 2.3 turbo motor i pulled out of an 88 tbird and put in my ranger (im used to big V8's), i just got it crankin over and runnin and it seems to leak oil im guessing somewhere in the timing gear area?...im wondering if it is the front main seal but it is kind of hard to tell...i know the little 2.0 that was in it leaked oil too and it also got shot all over the engine compartment from the belt...
im wondering if there is a typical leak that springs in these little 4 bangers....
Old 06-30-2006, 12:16 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
I'd look at the front main seal and the cam seal, but you might also check the turbo oil supply line.
Old 06-30-2006, 11:10 AM
jamnjm's Avatar
jamnjm
jamnjm is offline
The 2.3 front crank seal in held in a cover. Most don't know this, but you have to center the seal by moving the seal holder before tighten it down.
Old 07-03-2006, 07:45 PM
jimdandy's Avatar
jimdandy
jimdandy is offline
Smile
It is also common for the cam gear bolt to leak. Use lok-tite. jd
Randomnerd2000
Modular V10 (6.8l)
04-10-2017 01:36 PM
Iron lhorse
1983 - 2012 Ranger & B-Series
09-25-2016 07:02 PM
shultzaberger
20
05-10-2016 05:19 PM
Carnes99
Modular V10 (6.8l)
02-06-2013 01:22 PM
jr4racing56
27
11-17-2011 04:33 AM
Quick Reply: 2.3 common oil leak?
