67 ford truck ignition. Points to electronic???? - Ford Truck Enthusiasts Forums
Old 11-03-2000, 01:07 AM
john1245 john1245 is offline
john1245 is starting off with a positive reputation.
How do I convert a 67 ford truck (not sure what engine, 6 cyl I think) to electronic ignition? Suggestions appreciated.
thanks (Newbie)
John
Old 11-03-2000, 08:24 AM
William William is offline
William is gaining momentum as a positive member of FTE.
John: Use the Pertronix Ignitor system. This Hall Effect module is a screw on replacement for points, works with a stock coil and is not to expensive, about 80 bucks. Follow the instructions and if you can change a set of points you will be able to install this kit. Open up the gap in your plugs to .040.
William in Atlanta
Old 11-03-2000, 01:54 PM
rob3435 rob3435 is offline
rob3435 is starting off with a positive reputation.
Old 11-03-2000, 04:48 PM
stingray stingray is offline
stingray is starting off with a positive reputation.
The swap is really simple. First you have to obtain a distributor with an electronic pickup in it and the harness (From the module to the distributor and coil. Cut the female connector with two leads about six inches from the connector on the module). Most wrecking yards are full of these. Then remove the cap and see what color the plastic part of the pickup is. Go to a parts store and get a module with the same color grommet on it and a coil for electronic ignition. Install the distributor and plug in the harness to it. Connect the coil. Then mount the module on the fender or firewall and plug the harness into it. Connect the two-wire female connector to the module and that leaves two wires to connect. The Original red wire to the coil will connect to the white one on the connector, and the other red wire on the connector will connect to the "s" post on your starter solonoid. If you would like, I can E-mail you a diagram.
Electrical Ignition Problems Delp73 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-05-2016 08:43 AM
Ignition Hot Wire montauk1 1999 to 2016 Super Duty 5 07-24-2016 02:20 AM
Electronic fuel throttle control light John Shreves Modular V8 (4.6L, 5.4L) 10 05-11-2016 06:45 PM
Electronic Ignition Ford_Six 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-27-2002 12:54 AM
pros and cons of electronic ignition conversion cpt_insano 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-28-2002 01:16 AM
Tags
100, 289, 67, coil, color, convert, electric, electronic, f100, ford, harley, ignition, points, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
