'70 C6 trans output shaft and seal - Ford Truck Enthusiasts Forums
Old 11-14-2000, 01:26 AM
petel petel is offline
petel is starting off with a positive reputation.
I need some educating. Have a '70 C6, with 2WD extension housing. It leaks some ATF out the rear seal. If I grab the u joint yoke at the trans output, I can noticably move it up and down at the trans. Is this just normal slip joint spline tolerance? If I got this right, the trans output shaft has external splines, the u joint yoke has internal splines, the rear seal seals against the outside of the u joint yoke. There is mention of a bushing, does that bushing support the output end of the trans output shaft? Is there any internal seal on the trans output shaft that keeps ATF from washing the grease off of the slip spline area?
If the play is not normal, is the bushing most likely to blame?
Whats the best way to replace the bushing if it needs it? I don't have the special sleeve to grab the bushing and pull it out the back. Would it be better to pull off the extension housing to get a good look at the bushing? With the extension housing off, could I carefully pound out the bushing to replace it if needed?
Whadd'ya think?
Thanks
Old 11-14-2000, 01:33 PM
beartracks's Avatar
beartracks beartracks is online now
beartracks is starting off with a positive reputation.
As I recall it's not too hard to get the output housing off, four or five bolts and the speedo gear. Take the housing to a tranny shop to press in a new bushing and seal. Shouldn't cost a lot. There should be some play but not a lot. When mine was worn out it didn't really leak but would sometimes bind on staring out or stopping and make a clunk.
1977 Ford F-100
280,000 miles
Stock on the outside
modified/rebuilt everything
Old 11-14-2000, 08:21 PM
William William is offline
William is gaining momentum as a positive member of FTE.
Little drips and drops are not a problem, hell these are Ford trucks. Try a can of seal conditioner first. If it continues leaking and you do not have the tool to remove and reinstall the bushing, better have experts do that part.
William in Atlanta
Old 11-14-2000, 11:47 PM
beartracks's Avatar
I'd think twice about the seal additives. No offence but I hear they can work too good and cause too much swelling.
Consider just replacing the seal. Remove drive shaft, pry out the old one and use a socket to tap in the new one.
1977 Ford F-100
280,000 miles
Old 11-15-2000, 07:45 PM
TomC TomC is offline
TomC is starting off with a positive reputation.
Most trucks I have dealt with use a bolt-on yoke and a ball bearing on the inside of the housing. I can't remember if there is also a bushing as a car transmission has. Perhaps check and see if the retaining bolt for the yoke is loose or has been left out. If the bolt is loose or missing you will have a leak from that point.
Tom C.
Old 11-15-2000, 08:35 PM
stingray stingray is offline
stingray is starting off with a positive reputation.
The best conditioner money can buy is a pint of brake fluid. No kidding, brake fluid is just a high grade of hydraulic fluid. It has an agent that conditions seals and prolongs their life. It also has an anti-oxident to help keep any moisture from causing oxidation.
However I would recommend changing the bushing and seal if they are ever in question.
Old 11-15-2000, 08:42 PM
Transmission output shaft slop or play banjopicker66 Clutch, Transmission, Differential, Axle & Transfer Case 6 01-08-2016 09:20 AM
C6 Slip Yoke BushyTea 1961 - 1966 F-100 & Larger F-Series Trucks 2 05-02-2015 09:20 PM
1995 F-250 2WD 460/7.5L With E4OD: Odd Leak Out of Rear Of Transmission LvBohemian 1987 - 1996 F150 & Larger F-Series Trucks 0 11-11-2014 10:15 AM
Leaking output shaft seal corey3377 1968-2013 Full Size Vans 1 03-04-2013 09:06 AM
I need very quick help re: extension housing seal/bushing/tranny leak sixgunner 1997 - 2003 F150 14 12-11-2008 01:05 AM
Tags
bushing, c6, ford, grease, housing, internal, output, pull, rear, seal, shaft, steel, trans, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
